Old 06-07-2002, 06:50 PM   #1
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
*pic's* of 12 bolt rear disc brake install in my 71 Blazer
Finally finished my rear disc install on my 71 Blazer.I used the TSM kit.It took me about 2 days(taking my time)and went real smooth.
I am having trouble getting the air out of the system(see my post-CAN'T GET A HARD PEDAL) so the jury is out on any braking performance improvments as of yet.
Total cost was roughly $400.00.Prob. could have done it a little cheaper but I went with new parts instead of used ones.
Click the link to see the pic's.
http://www.imagestation.com/album/?id=4292219125
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 06-07-2002, 07:28 PM   #2
StingRay
StingRay's Avatar
Nice job and nice documentation of it.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 06-07-2002, 07:30 PM   #3
Chevyc10!
Chevyc10!'s Avatar
Checked out the pics, man looks like you did a hell of a job! Come on over, lets get started on mine! I got a fridge full of beer!
68 SWB
The Surgeon General doesn't say anything about smoking a Ford!!!
Would rather be ran over repeatedly by a Chevy than drive a Ford!!!
Paralyzed from the neck up and confined to a hat!
Kathleen, Georgia USA
Chevyc10! is offline   Reply With Quote
Old 06-07-2002, 09:33 PM   #4
ColinOpseth
oh man, that would make a great tech article for my website..
would you be interested in writing one up? you can basically just write in the instructions and i'll go through it and make it more readable
of course, you'll get full credit..
lemme know if you're interested as I'd like to do this swap myself and your pictures would be the perfect addition to a good writeup
thanks,
Colin
Webmaster: www.h-body.org
ColinOpseth is offline   Reply With Quote
Old 06-07-2002, 10:18 PM   #5
JHickson6
I Love This Stuff!
JHickson6's Avatar
Thumbs up Very Nice
Awesome pictures
You have given me a lot of confidence to do mine!!!
JHickson6
JHickson6 is offline   Reply With Quote
Old 06-08-2002, 12:08 AM   #6
BobbyK
BobbyK's Avatar
Colin,no problem use the pic's if you want.Let me know what kind of description you want and I'll do my best to describe the steps of the install.
JHickson6,I'm from Winnipeg as well but at present working in California.I'll be in the "peg" in Aug. but not with my Blazer.
Glad you got something out of it.That's the main reason I document the mods I make.I know if I'm up in the air about doing a mod. and I see pic's of how some-one else did it it really helps me.
I give credit to a guy named Steve Chin,he's a member at coloradok5.com.He did the swap before me and did a excellant job writing it up,just no detailed pics.Still his article helped me GREATLY!!!
Old 06-08-2002, 12:17 AM   #7
Low69CST
Nice job! What do you use to get those nice looking pics?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-08-2002, 12:35 AM   #8
BobbyK
BobbyK's Avatar
I use a Nikon digital camera.It's a COOLPIX 880.Takes great pic's.
Old 06-08-2002, 12:08 PM   #9
ColinOpseth
Hey Bobby,
Basically, whatever you can writeup will be fine. I've been looking for quite awhile for the details on this swap so any information that you have will be great
Maybe you have the part numbers of the parts that you used (seals, bearings, etc) or something. Any installation instructions oyu want to add and any tips that you might have that would be useful would be great, too
I'll see if I can work out some compensation for you because it'll be a fairly extensive article. I can probably fire you off a few bucks to write it up..
Thanks again man,
Colin
Old 06-08-2002, 12:10 PM   #10
ColinOpseth
oh, here's one i wrote on how to change your EGR on a tuned port injection engine
http://www.gmperformance.org/modules...rtid=10&page=1
Old 06-08-2002, 03:55 PM   #11
Mike C
Mike C's Avatar
Cool. Nice to know you can get a kit with e-brake for that price. Nice job on the photos. Did you ever get the air out of them?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-09-2002, 12:41 AM   #12
BobbyK
BobbyK's Avatar
No not yet.I work nights all weekend so I'll get back to it on Monday.
ColinOpseth,once I get all the air out of the brake system and have it up and running I'll put together a small write-up describing the steps I went through during the install.I'll enclude any part Numbers I have as well.
Old 06-09-2002, 12:54 AM   #13
ColinOpseth
hey Bobby,
thanks so much, dude.. i really appreciate it you'll get full credit on my site, of course
Old 06-16-2002, 11:05 AM   #14
ebfabman
BobbyK,
did you get the e-brake hooked up? If so, how does it work?
ebfabman is offline   Reply With Quote
Old 06-17-2002, 01:32 AM   #15
BobbyK
BobbyK's Avatar
Yes I did.I reworked the factory e-brake cables and was able to make things work.
1st I took the orig. e-brake cables off the truck.
2nd-I enlarged the holes on the e-brake cable braket (on the new Eldorado caliper)so the factory cable would fit(just filed it out a little)
3rd-I cut about 2" of the end of the orig. brake cable.
4th-removed the spring that's on the orig. e-brake cable.
5th-put a grade 8 nut over the cable end and with a BFH smushed it so it is clamped onto the end of the cable.
6th-re-installed old cables back into the truck.
7th-adjust the 2 nuts on the cable that goes to the brake lever in the truck to get the slack out of the cable.
8th- applied the e-brake about 6-10 times to set the brake pads on the rear disc brakes.
The e-brake works well.If your vehicle is lifted you will need longer e-brake cables.
I didn't take pic's of me doing this but if anyone needs pic's I'll go and take pic's of whatever you need.
Old 06-17-2002, 10:38 AM   #16
slam33
slam33's Avatar
You did a nice job.What size are the discs ? Who's calipers are used ?
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 06-17-2002, 03:23 PM   #17
Mixup
Bobby who is TSM? Every kit I looked at was about $500. thats a good price.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 06-17-2002, 08:18 PM   #18
BobbyK
BobbyK's Avatar
The rotor are about 11" across.the rotor are just the ones used on the front disc brakes.Six new 7/16 holes are drilled in them to fit the rear axle.
The Calipers are from a 84 Cadillac Eldorado.
Here is a link to the TSM site.
http://tsmmfg.com/General_Motors_truck_rear_axles.htm
