Old 04-11-2005, 03:16 PM   #1
cwilkie
Chance
cwilkie's Avatar
Gear Ratio
What is the gear ratio in a 71-72 rear end? I had my gears switched when I came across that rear end since the gears in my 1968 were so low gear. However, I forgot the gear ratio and I have to know because I want my speedo to be correct.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 04-11-2005, 03:28 PM   #2
CHEVY & GMC FOREVER
Not enough info, but if I had to guess I would say maybe 3.43, 3.73, or maybe even 4.11, hope this helps.
1985 Chevrolet C-30 454 1-TON Dooley
1969 CHEVROLET CST-10 PICK-UP
Good memories
1999 Chevrolet Z71 Ext. cab 5.7L
Good Memories
With a quart of oil, and a gallon of gas, she won't let no other car pass!!!.
& FOREVER
CHEVY & GMC FOREVER is offline   Reply With Quote
Old 04-11-2005, 03:28 PM   #3
'70_402
'70_402's Avatar
There Was Not One Gear Ratio In Those Years...you Either Had 3:08,3:42,3:73,or 4:11.... Search The Board Here For Some Threads On How To Figure Out What Ratio You Have..
'70_402 is offline   Reply With Quote
Old 04-11-2005, 04:20 PM   #4
farside847
farside847's Avatar
Josh answered this for me earlier:
If it's a stock 307/3spd they all got 3.73s unless ordered otherwise, 350s got 3.07, big blocks got 3.54 and all sixes got 3.73.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 04-11-2005, 09:21 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
farside, those gears you listed are fairly acurate, but only for 1/2 ton trucks, and all are as base equipment. With certian exceptions (like the 4.10 to a big block) you could get any ratio with any engine tranny combo...but what you listed is fairly acurate for base equipment.
In all reality, it is probably a 3.07 gear. However, i always recomend doing a tooth count on the gears becouse some one could have installed a 3.42 (never factory installed) and the oil probably needs chainged anyways.
Old 04-11-2005, 11:44 PM   #6
JodysTransmissions
JodysTransmissions's Avatar
cwilkie:
Most any transmission shop should be able to help you with a speedometer calibration. We do this all the time for customers. Any gear ratio or tire diameter change will effect your speedometer/odometer reading.
Regards, Jody
JodysTransmissions is offline   Reply With Quote
