Old 04-15-2005, 11:40 AM   #1
fire235
frame to cab mounts
Can I replace the bushings on the cab mounts without removing the entire cab? Mine need replaced and I was hoping I could do without much trouble.
Thanks guys.
fire235 is offline   Reply With Quote
Old 04-15-2005, 12:17 PM   #2
David Johnson
David Johnson's Avatar
Yes they can be replaced without removing the cab. Just take out the bolts (4) and put a little pressure on the bottom of the cab with a floor jack, remove and replace the mounts. The old ones are probably smashed down and the new ones will be thicker, so you'll have to lift the cab a little with the jack. By the way, you should replace your radiator core support bushings too. If you don't, you may have problems with your fenders wanting to shift on you which will effect you door opening. Also, since you've gone this far, you might as well replace the bed pads. Hope that helped.
David Johnson is offline   Reply With Quote
Old 04-15-2005, 12:33 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'd also loosen or replace the rad support mounts also.
Looks like I didn't read far enough. Also be prepared to cut the bolts off and replace them. I had to with 4 out of 6 on my GMC.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-15-2005, 12:53 PM   #4
fire235
Thanks for the info guys. Guess I'll get started replacing bushings now.
Old 04-15-2005, 08:52 PM   #5
JimKshortstep4x4
Talking
All the cabs that I have seen have the front cab mount bolts welded to the floor, (the large 9/16 diameter bolts). You may want to grind the welds so as to remove the bolts otherwise the cab will have to be lifted high enough to clear.
Jim
Old 04-15-2005, 09:11 PM   #6
Sweet72
Sweet72's Avatar
Jim
Mine were not welded. Maybe they welded them so one man could install the cab from under the cab and the bolts wouldn't turn. The rear cab mount bolts are installed from the bottom up and threaded into cage nuts.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-16-2005, 02:16 AM   #7
David Johnson
