Old 04-18-2005, 12:57 AM   #1
JadeEmperor
Outer grill shell swap - rivets?
For anyone that has done a shell swap or others with ideas, what did you use to attach the supports on the sides so that it would bolt up to the fenders. The factory rivets look like solid rivets, I have "pop" rivets, but was wondering if there is any way to reattach the brackets with a simple rivet that will look like factory and not have a hole in the face like blind pop rivets do.
Jimmie
Modern Vintage Autoworks
- '70 Chevy C10
- '74 Chevy C30 3+3 Dually
- '04 Chevy Colorado
Built, NOT, Bought. If you build it...they will ENVY!
Drive Slow, Scrape Hard, or Take Your Truck and GO HOME!
JadeEmperor is offline   Reply With Quote
Old 04-18-2005, 07:31 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I've been using the threaded style rivet for all my cars. From the top, it looks like a factory rivet but on the bottom, it has a threaded shaft and uses a small nut.
The only place I know of that has them is Lutty's Chevrolet warehouse but I'm sure there are many others, somewhere... They are $6.00 for 15 rivets. (I think) Part number 7964.
http://www.luttyschevy.com/pages/home.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-18-2005, 11:41 AM   #3
Yukon Jack
Yukon Jack's Avatar
I used something that sounds like what bobs409 used. Mine were airplane surplus fasteners.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-18-2005, 11:54 AM   #4
JimKshortstep4x4
I usually just use pop rivets and paint them flat black. Some of the vendors carry grill installation kits that have the solid pop rivet in them.
I have also turned down small stainless bolts so they look like rivets.
Jim
Old 04-18-2005, 11:56 AM   #5
cdowns
cdowns's Avatar
in my area there's alot of fastener stores and even some hardeware stores carry aluminum rivets. check out the local yellow padges for stores like that.
i think they use them alot in screen enclosures like by the swimming pools
