Old 04-18-2005, 02:21 PM   #1
ScottH
ScottH's Avatar
Steering wander problem, opinions needed
My 72 C20 has a steering wander issue that is really annoying.
I need to turn the wheel slightly to the right then slightly to the left, then repeat process in order to go straight down the road.
I checked the steering linkage and everything seems tight, replaced the idler arm and sway bar bushings. I also tried tighting the steering box but that seemed to make the problem worse.
Right now I'm thinking the box is worn but would appreciate any opinions, suggestions, or ideas to try before I replace the steering box.
Thanks.
Scott
ScottH is offline   Reply With Quote
Old 04-18-2005, 03:32 PM   #2
shifty
Questionable
shifty's Avatar
Sounds like your box is worn out. Mine's in the same shape. Hope to upgrade to power soon.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-18-2005, 03:34 PM   #3
Tim240Z
Tim240Z's Avatar
Have you had the front end aligned? Insufficient caster can cause wandering and instability. Also, a decent alignment tech will be able to diagnose any problems in the steering system.
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 04-18-2005, 04:16 PM   #4
dubie
dubie's Avatar
does the steering wheel flop from side to side a bit when you ftap it? If so then your steering box is toast. They can be adjusted but I'm not exactly sure how
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-18-2005, 06:29 PM   #5
Sweet72
Sweet72's Avatar
Like said before get a front end alignment. It could be the "toe-in" isn't correct, worn tires and shocks can cause some weird s*&t too. Are you able to get much free-play left and right in the steering linkage? Your steering box may be fine if you have little or no play from steering wheel to the front wheels.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-18-2005, 06:56 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
loose steering
Around here most alignment shops won't check alignment on loose front ends until whatever is wrong gets fixed. Any good garage should be able to check the front end out and find the trouble. It sounds to me like worn tie rod ends or center link or a combination of the two. If someone turns the steering wheel back and forth while you look at the steering linksge you should be able to see excessive movement somewhere before the tires move.
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-18-2005, 08:23 PM   #7
zeeklu
Sounds like it could be a frozen ball joint. Chris
zeeklu is offline   Reply With Quote
Old 04-18-2005, 10:42 PM   #8
ScottH
ScottH's Avatar
Thanks to everyone, will have to look into a few things.
Hey Chris, just talking about u tonight - please pm me so we can square up on what I owe you!
Old 04-18-2005, 10:45 PM   #9
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
While you're checking don't forget that ever expensive pitman arm.It is expensive,and most of the time doesn't get replaced.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-19-2005, 12:28 AM   #10
Elsie72
Chinook Arch
Elsie72's Avatar
I just did a pitman and idler in mine, and the steering was very imprecise before, and tight and new-feeling after. I spent the extra bucks on Spicer parts, which may just outlast the rest of the truck.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
