Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-18-2005, 05:57 PM   #1
Greenlee
Greenlee's Avatar
WTB: 10 bolt or 12 bolt with 3.73's in Houston area
The gears in my 76' are too high for the 700r4 that was swapped in. Also, I just noticed that the rear end is leaking a little oil around the yoke. Rather than fix it and replace the gears, I figure it would be easier and cheaper to just replace the rear end. If anyone has one, send me a pm.
Greenlee is offline   Reply With Quote
Old 04-18-2005, 07:34 PM   #2
bigarmzz
bigarmzz's Avatar
Originally Posted by Greenlee
The gears in my 76' are too high for the 700r4 that was swapped in. Also, I just noticed that the rear end is leaking a little oil around the yoke. Rather than fix it and replace the gears, I figure it would be easier and cheaper to just replace the rear end. If anyone has one, send me an e-mail: scgreenlee@sbcglobal.net
the pinion seal is easy to fix.....cost less than $10
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 04-19-2005, 02:43 PM   #3
Greenlee
Greenlee's Avatar
Thanks for the tip, I may end up just fixing it if it is that easy. I want lower gears and I figured I might be able to buy a used rearend cheaper than I can get just the gears.
Old 04-21-2005, 12:24 PM   #4
grape
grape's Avatar
I've got a set of 3.73's that have about 500 miles on them. I changed to these from the factory 3.08's, then changed transmissions that had different overdrive ratios so i promptly took them back out. I'd take $50 for them. The tail bearing and shim is still on there so the pinion depth and set up should be close. Let me know
grape is offline   Reply With Quote
