Alignment questions
I am doing bags and drop spindles on the front of my 72 2wd Blazer and was wondering if I need to get longer upper a-arm mounting studs or am I going to be able to move the arm out far enough to get it aligned at ride height. Also is changing these studs a pretty easy job to do. And where would I get them from if I need to change them.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA Last edited by 72BLAZERDUDE; 04-19-2005 at 06:15 PM. |
dunno for sure but i think you'd be fine, it shouldnt be too far off with a drop spindle....and aired up to ride height....
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!! 09 - Harley nighttrain on air ride! |
You need to move the upper a-arms "closer" to the frame when you lower. So no need to get longer bolts.
A little more the 2 inches spring drop is all you can go before you get into front end alignment problems. This is with the stock A arm set up.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
I am not sure I understand. Wouldn't " closer " to the frame be opposite of what I want to do. I understand longer bolts which means more shims which means farther from the frame. Having not looked real close at a crossmember out of a truck is it not possible to space out the mounting plate. I know it is riveted to the top of the crossmember but can it be moved.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
Progress = 0%
Yes, the upper a-arms need to move outward when a truck is lowered to get the camber right.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#6 | |
72Blazerdude, you should be fine w/the stock studs when using drop spindles + bags up front. Your estimated front drop will prob be around 5-6" @ ride height which is common even w/static drops. My 68 & 74 both utilize the stock length studs & both are static dropped 5-6" in the front.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-23-2005 at 12:18 AM. |
This has been my experience with my 69 SWB with 71-72 upper and lower A-arms. 2.5 inch drop spindles plus 2 inch drop springs with all ball joints and bushing replaced.
to get: -0.25 chamber and 2 degrees caster There is no shims in the front part of each a-arm front bolt Two 0.125 shims on passenger side back bolt Three 0.125 shims on the driver side back bolt using the gauge like the one in this auction http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
I left out a key word so I edited my original post.
I'm going to recheck my chamber and caster today. I bet the difference is in the spindles top ball joint hole location.
#10 | |
Progress = 0%
After reading Frank Z's post I remembered a 66 truck I dropped for my old neighbor (using Turners stepped arms & 1 coil cut from stock springs). It required removal of front shims vs. the typical adding of shims.
I know the avg./typical truck drop will require spacing the arms out, but I guess some are different. Cars do require moving the arms inward because of the mounting orientation of the a-arms.
