Crazy
Tonneau cover on a 77 stepside
Is anyone aware of any manufacture that makes a tonneau cover for a stepside truck that will not require me to drill any holes? I have some ideas about how to adapt a cover to the truck without any holes, but wanted to see if there is any out there that already have it available first. Thanks.
I made my cover out of plywood, 2x4's and vinyl. Turned out real good. I can sit, jump, lay whatever on it with no problem. No holes.
*Proud Member*
my stepper came with a custom tonneau, but as you noted, it was the drill holes type.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
http://www.gaylordslids.com had some I was looking at a while back.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Crazy
THanks for the info guys.
here is one I just made for mine.
75 GMC C-15 short/step factory 454, lowered |
I did however have to drill 4 small holes on each side to attach the 1" aluminum angle to the bedsides with rivets
Stepside, do you have any more pictures of that cover you made- like how it pivots and things like that. Does it latch down or just rest on that lip? I was thinking up an idea like that and it looks like yours turned out really nice, so I think I might try and go through with it. Anything I should know before I start gathering up parts?
Damn, I ask a lot of questions ![]() |
I used 1" aluminum angle & 1" aluminum square tubing, 3/8" plywood. had a buddy weld the aluminum for me. that fron piece is bolted down. the rear pice uses those tabes you see in the one pic to hold the front edge of the rear piece in place. than I have 2 locks, 1/4 turn, like used on pinball machines to secure the rear. it turnes out pretty decent, thanks, John
Thanks, I see what you're saying. I like the idea of the two piece cover. I think I might go to home depot and see what I can find there as far as the aluminum.
Mine is basically the same as stepside454. But. I didn't use aluminum and mine does not sit flush with the sides. Both of which I like, looks great stepside454. Mine is all wood, vinyl and foam cushion.
http://img.photobucket.com/albums/v2...r/6dc0b98c.jpg |
*Proud Member*
nice stepper - what did you use to drop it?
Thank you for the nice comment, I appreciate it. I lowered mine 20 yrs ago, before the was such a thing as "lowering kits". I used a cutting torch, cut and welded the spring brackets in the back and removed a few leaf springs. I have been looking at doing it again and using a modern lowering kit. Maybe with drop spindles. I also would like to drop the rear alittle more, but I need to c-knotch it. Now days, you can get a c-notch kit where you just cut the frame and weld or bolt in the notch. Much easier these days.
looks great Nolow
#15 |
Until Seventy Times Seven
Good looking truck, Nolo.
![]() Dig the shoes and the frenched antenna. What color is your truck? Got any more details/pics of it?
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#16 |
yeller
nolowrider, beautiful truck man...beautiful!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#17 |
Thanks guys for the comments. I appreciate it. The color is actually a Ford color (I know that is a bad word here). Vintage maroon. I have a 1967 Mustang that painted and I really liked the color, so I had them shoot my truck too. I have to upload more pics tonight (if you really want to see more). Thanks again guys.
