Old 06-11-2002, 12:28 AM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
What are the widest tires that can be fit under the wheelwells?
I have seen lots of pics of these trucks in the Pro Street fashion. What I am wondering is what is the largest tires that can be fit between the fender and the frame rail? I do understand that the box would need modifications to the wheel tub area. I am thinking somewhere around 12-14" wide?
Thanks!
p.s. pics would be cool also.
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 06-11-2002, 12:46 AM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I run 31X10.50X15's with no problem. They've never even offered to rub and thats with a totally stock stance. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-11-2002, 02:21 AM   #3
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
I've got 32x12.50's on my truck, didnt have any problems front or rear until i switched out my spindles, now it'll rub when i go over a speedbump/dip too quick (20+) sucks but i'll fix it soon. The rears clear no problem from what i can tell, but i'm yet to load 3tons in the sucker so i dunno
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 06-11-2002, 04:34 AM   #4
Alexis
Member since 2000
Alexis's Avatar
285/40/20, good fit, havent driven on it but i think if i turn hard enough it would rub unless i get a rear sway bar, might help .
Alexis is offline   Reply With Quote
Old 06-11-2002, 08:19 AM   #5
Zkast
Zkast's Avatar
I've got a set of 295/50R15 which is 14" wide I believe (could be a bit smaller) and have no trouble at all. I havent checked to see if anything wider would fit. These seem to hook up pretty good though and lowering the truck didnt bother them. They tuck under the wheel well nicely.
Zkast is offline   Reply With Quote
Old 06-11-2002, 12:56 PM   #6
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
im puttin 29x15.5x15 on mine, i had tub it and move the e-brake cable clip. w/ 12'' rims i had to have 8'' backspace. ive seen a 70 lwb w/18.5'' he had to do the same stuff but he also had to remove the bump stops and cut away some of the ends of the trailing arms.
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 06-11-2002, 11:27 PM   #7
REPO1
Shortbox wanna-be.
REPO1's Avatar
I'd love to see some pics of that once its got those tires under it!
Old 06-12-2002, 06:59 PM   #8
SCOTI
SCOTI's Avatar
I used to have 31x18.5x15" Mickey Thompsons on 15x14" wide ralleys w/9.5" backspace, no frame or rear-end mods necessary
(e-brake cables were hooked up but I dont know if they would have worked properly)but did stretch the tubs 9". Although I never actually drove it like that, the wheels & tires fit w/no probs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-12-2002, 10:15 PM   #9
PushinPebbles
My dad's 68
PushinPebbles's Avatar
My dads 68 is tubbed w/ a chevelle 12 bolt the tires are mickeys.............i believe that they are 33/??/15.....................
I can post pics as soon as i get home (friday)
..........................Jack
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
