04-23-2005, 10:56 AM | #1 |
like a rock
pictures of 3/4 ton 2wd's
i would appreciate if you guys could post pictures of 3/4 ton 2wd's. I have got a 3/4 2wd frame and I am deciding weither or not to make a build out of it. SO POST SOME PICTURES OF COOL 2WD 3/4 TON PICKUPS. Thanks Brian
04-23-2005, 01:40 PM | #2 |
Web Wheeler
You can do mostly everything with a 3/4-ton that you want to do with a 1/2-ton. You just end up with 8-lug wheels, better brakes, firmer ride, longer service life, and a slightly heavier truck.
Great choice to tow with. REALLY easy to upgrade to 1-ton if desired. IMO, most people miss the boat hopping up the less-capable 1/2-ton truck.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
04-23-2005, 04:55 PM | #3 | |
04-23-2005, 06:58 PM | #4 | |
Web Wheeler
On the rear, I swapped a 14FF in place of the 14SF, then added 1-ton backing plates, drums, & shoes. On the front... balljoints, knuckles, rotors, calipers. Master cylinder is different, but the 3/4-ton one will still work. Springs can be changed, but not necessary. A-arms are the same between 3/4-tons and most 1-tons. (There is a high GVW variant, rpo F42, for which the arms attach differently and requires the whole crossmember to complete the swap.)
04-23-2005, 02:54 PM | #5 |
North Coast, baby!
There is already a thread on this over here: http://67-72chevytrucks.com/vboard/s....php3?t=147730
Brad 79 Scottsdale C20 350/350 3.73's Still running full CA smog gear! |
04-23-2005, 05:14 PM | #6 |
Professional Grade
Different rear leaf packs, and different front coils / a-arms
Not a tough upgrade at all. A 1 ton frame is different from a 1/2 ton and 3/4 ton frame(the rails on 1/2 ton and 3/4 ton are the same part number, even between 4x4 and 2wd!), however, everything bolts up between the three frames.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
