Old 04-24-2005, 10:02 AM   #1
hilljob26
hilljob26's Avatar
can i put a cv joint on the rearshaft
i have a 72 chevy 4x4 but i am using a tcase out of an 80 blazer that has a slip yoke,can i put a constant velosity (like the front has) behind the yoke,will that work ok,my truck is lifted 6 inches and i just though that that would make a better angle for my driveline
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 04-24-2005, 10:34 AM   #2
Mudder
Mudder's Avatar
Usually the rear is done by placing a wedge under the leaf pack.
Mudder is offline   Reply With Quote
Old 04-24-2005, 10:14 PM   #3
Mike C
Mike C's Avatar
I'm not sure how the dynamics of the slip yoke plays out, but I have a rear CV on my Jimmy but using a two piece shaft. I had to change the output yoke and other than that, bolted right on. With 4" springs in the rear, the length of the Jimmy shaft was just too short. Tom Woods build mine when he was with 6 States. Has his own shop now. You can rotate the housing up like Mudder says, but you wind up with a driveline that is out of phase. Angles on top and bottom should be same with a conventional driveshaft. Using the CV, you want zero degree angle on the axle (driveshaft inline with pinion) and all of the rest at trans. This works well with aftermarket springs that use a wedge to rotate axle housing to minimize binding. Honestly, with a truck the length of the shaft is sufficient you should be able to lower the back of the T-case and use wedges at the axle to correct driveshaft angle. Especially if it is a longbed truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-25-2005, 02:18 AM   #4
Mudder
Mudder's Avatar
Didn't think to say. My TC has been dropped for many years and I have a 4". I get the angle under the springs with the blocks. The blocks and the TC was done back in the early 80's when it was a 77 truck and done a lot of mudding. Someday...... I may get a different frame and at that time I may go to all springs lift.
Old 04-25-2005, 06:24 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My neighbor's ford has a cv joint at the rear of transfer case but the slip joint is in the driveshaft not tailshaft of the tc. The funny thing is his front does not have a CV joint, it's a 79 w/ a high pinion dana44 up front.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-25-2005, 09:00 AM   #6
jcueckert13
jcueckert13's Avatar
actually its a double cardan joint not a cv joint
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 04-25-2005, 09:47 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Got me.
Old 04-25-2005, 10:10 AM   #8
Esteban86K5
Esteban86K5's Avatar
That is what I had on my truck. I did the shimming and lowering of the t-case and could never get rid of the driveline vibes. So I went with a 1 ton CV and never had a problem again. I raised the t-case back to normal hieght and cut and welded the spring perches to obtain the correct pinion angle instead of useing shims. I run the slip yoke and it worked fine.
Be American Buy American
My Pics
Esteban86K5 is offline   Reply With Quote
Old 04-28-2005, 10:18 PM   #9
hilljob26
hilljob26's Avatar
well i have a 6 inch lift w/ blocks in rear,and they are tapered,am i ok running a regular driveline,it only has about 1" of shaft sticking out of the t case,hope it works
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
