Old 04-26-2005, 12:49 AM   #1
Goplay2
Question New wiring HELP.. Painless or M&H
Painless kit 10206 $309.00 or M&H for $950.00
Pro and cons.
70 chevy going back semi stock with old air, hei and new tilt steering. i would like a clean setup (like stock but cleaner)
i have read a lot of post on painless but have not seen to many on m&h.
and thought??
Goplay2 is offline   Reply With Quote
Old 04-26-2005, 12:55 AM   #2
68LSS1
68LSS1's Avatar
Personally don't care for Painless. I like M&H. But I prefer Ron Francis. They can also build the harness for what ever plug you need for the alternator, steering column, etc.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 04-26-2005, 12:59 AM   #3
Goplay2
have you used ron francis on your truck? and if so can i get a pic. i have clean up the firewall so i would like to use the holes there. thanks
Old 04-26-2005, 02:27 AM   #4
GMCPaul
Goplay2 if you decide to go the M&H wiring route check out our web site electrical wiring pages, we only carry M&H wiring harnesses at 25-30% below there retail prices. You'll find the wiring here
http://www.gmcpauls.com/Electrical.htm
GMCPaul
GMCPaul is offline   Reply With Quote
Old 04-26-2005, 04:12 AM   #5
NPilot1975
NPilot1975's Avatar
Goplay2-
I used the Painless kit and found it to be really well made. It was easy to install and came with well written instructions. It is very versatile, I am running a '95 LT1 with all the factory accessories and the kit had everything to hook them up to include the correct wiring for the altenator.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 04-26-2005, 08:22 AM   #6
mocwon
Keep On Truckin'
mocwon's Avatar
NPilot1975,
Not to hijack the thread, but how did you wire the Painless system into the neutral safety switch? The stock GM column switch only has 4 wires and the Pinleaa harness requires a fifth one to be hooked to the switch.
Originally Posted by NPilot1975
Goplay2-
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 04-26-2005, 10:42 AM   #7
NPilot1975
NPilot1975's Avatar
Mocwon-
Are you talking about for the LT1? I actually used a combination of the switch housing that came on the colmn and the guts from a switch like the one they show in the instructions. The screw holes did not line up for the replacement switch, I believe it is from a newer model truck. You just have to be careful as you bend the tangs not to break them off.
Old 04-26-2005, 11:17 AM   #8
Inspector722
Fixing my 67, & loving it
Inspector722's Avatar
How about the EZ wiring? Is it any good? Runs about $150 on Evilbay. Has anyone tried it? I know I have heard you get what you pay for. Just wondering.
Email address- inspector722@aol.com
Zip Code- 77611
Shipping- DHL & USPS
Working on: 67, large back glass, 307 V8, 200 4R, 3.73 rearend, Short Stepside Bed
Inspector722 is offline   Reply With Quote
Old 04-26-2005, 12:52 PM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
NPilot1975,
No, mine's an '87 MAF setup off a Camaro. The stock '72 Chevy gear shift switch is completely different and the switch recommended by Painless isn't even close to fitting. I'll keep poking around. Thanks
Just Passin' Thru
Old 04-26-2005, 02:15 PM   #10
NPilot1975
NPilot1975's Avatar
mocwon-
I looked through the catalog of switches at NAPA and found the one that looked like the one that painless has. There are a few styles, the all plastic one will not work. There is one like it with a metal back. Like I said, I had to use the metal back from the original switch and put the guts from the switch I bought from NAPA. If I wasn't overseas I would look for a part number on it.
Old 04-26-2005, 03:43 PM   #11
mocwon
Keep On Truckin'
mocwon's Avatar
mocwon-
Thanks. I finally found someone at Painless that could help me; they have an adapter for this problem:
Just Passin' Thru
