![]() Join Date: Jul 2001
I'm sure this has been covered before but need to ask. My '71 4x4 is getting closer to coming out of the paint & body shop. Have no idea what is original floor covering other than the black rubber floormat. When I bought the truck there was't much of that left either. I have a repop floor mat for 4x4 with tails but what do I need to go under it as far as sound deadening, insulation, moisture barrier? Any suggestions ? Thanks in advance to all replies.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
there is molded carpet you can buy, or just the white 3/16 inch foam, then the mat, if your goin original. good luck, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
The factory had some kind of cheap insulation, I think I threw all of my old stuff away. You can buy replacement original stuff like mentioned above, you can also get some insulation from summit that is much better, or you can take the "got money to burn, overkill" method like me and dynamat it.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Oops, forgot the picture
Another one
