Removing dash bezel - Question?
I am changing my dash bezel for a new reproduction one. Last time I took my dash bezel out, I had a hell of a time getting the headlight knob out. Is there a release for the headlight knob rod behind the dash bezel, or do you just pull hard until it releases. I don't want to break anything.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
feel up in there and the back of the headlight switch is like a box, right on top there is a button, push the button, hold it down, and pull it out. good luck, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
Thanks bens86, I thought that there must be a release for it somewhere. Appreciate the good info.
no prob, i learned the hard way
one other thing. You can't push the button down unless the knob has been pulled out one click (I believe) then hold it down and pull out the knob/shaft. Don't forget to diconnect battery
72 swb cheyenne super 350/350 69 cst20 BB longhorn Warren, OR |
