Old 04-28-2005, 09:11 PM   #1
greenhorn male
greenhorn male's Avatar
Question Temperature guage???
I replaced the sending unit today on the block.
Guage still reads past max, all the way right. My last two trucks had aftermarket guages under the dash. Do these guages go out easily? Is there a fuse? What do you guys use for a temperature guage. What do you use to hold the wire onto the sending unit? For now I am using alligator clips. Thanks for any input or advice.
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
Old 04-28-2005, 09:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Your wire is grounding out somewhere. Follow that green wire and see if it is melted on a manifold or pinched somewhere.
Old 04-28-2005, 09:35 PM   #3
rico_bob
"Treasure the Ride"
rico_bob's Avatar
LH, 28,391 posts? MAN you must live here! LOL
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 04-28-2005, 10:23 PM   #4
Longhorn Man
I just have no life...that is all.
Plus, the 67 - 72 pages are 20 times more active than the 55 - 59 or the 60 - 66 parts of the site.
Old 04-28-2005, 10:49 PM   #5
69ChevyLB
Active Member
69ChevyLB's Avatar
I'm having the same/similar problem. Temp guage starts out cold and maxs out as the engine warms up but the engine gives no indication it is running hot. What gives?
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 04-28-2005, 11:26 PM   #6
greenhorn male
Could mine be stuck. It is always on the right side whether or not the ignition is on. I should have added in my first post that when I got the truck a couple of months ago, the temp needle was already in that position and the green wire was just dangling next to the engine with a burnt or rotted off clip or whatever it had to connect to the sending unit. The green wire feels stiff for its size but the conductor doesn't look bad after peeling back the green insulator.
03 Tahoe
Old 04-29-2005, 12:32 AM   #7
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Have you been able to test the gauge in any other way? Perhaps the gauge is the problem and not the sending unit? rico
