04-29-2005, 03:23 PM | #1 |
Need: Bushings for NP205 shift handle
1972 K20 with four speed manual and the 205 t-case. The t-case shifter rattles above 50 MPH (really annoying and loud). I tried putting some grease in, but just pours out the side.
Buddy said there may be a bushing for the handle? If not, any recommendations? Thanks, D.
'72 Chevy K-20 Crate 350, SM465, 4.10's |
05-02-2005, 12:00 PM | #2 |
I could not find replacement stock bushing anywhere. I had my buddy make me a new metal sleeve on the lathe and got off-the-shelf bushings from McMaster Carr. If you can find a later model adapter they use a different bolt that is still available.
'70 K-20 San Diego, CA Last edited by poff; 05-02-2005 at 04:47 PM. |
05-02-2005, 04:23 PM | #3 |
I tried everything including "Factory" plastic bushings and they were still sloppy and my bolt continued to come loose. Finally I Went to ACE hardware with the shifter and the bolt. I found 2 bronze bushings which fit into the shifter hole and allowed the bolt to fit through perfect or maybe a little tightI may have sanded the inside slightly. When they when pushed together from both sides of the shifter piviot hole were a little long so I ground one of them down. The shifter is rock solid and has not come loose or rattled since 2002.
