Old 05-01-2005, 05:00 AM   #1
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
how to lose 50lbs in 2 days
and its 2 days cause i am too lazy to bust mu butt to get it done in one. the cast heads weigh 55lbs and the aluminum ones weigh 25. i will finish it all up tomorrow. as it sits all the valves are adjusted. so on with the intake and headers and we are done and then
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-01-2005, 07:02 AM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
thats a mean diet ... what are the specs on the heads
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-01-2005, 12:52 PM   #3
68w/sbc406
68w/sbc406's Avatar
they are ZZ4 heads 58cc, 194 intake http://67-72chevytrucks.com/vboard/s....php3?t=140933
Old 05-01-2005, 01:05 PM   #4
tmcgrawlookalike
did you decide to change cam also?
tmcgrawlookalike is offline   Reply With Quote
Old 05-01-2005, 01:06 PM   #5
71swb4x4
71swb4x4's Avatar
Looks cool.
That's some funny math you are doing
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-01-2005, 01:09 PM   #6
68w/sbc406
68w/sbc406's Avatar
naa cam is already lumpy
Originally Posted by 71swb4x4
Looks cool.
yeah i really am just changing the heads for weight reduction
Old 05-01-2005, 01:15 PM   #7
tmcgrawlookalike
was remembering this from last week or so and i knew you were possibly considering a cam swap.bumping up that compression may in turn make your cam sound a little more nasty
Old 05-01-2005, 01:27 PM   #8
68w/sbc406
68w/sbc406's Avatar
yeah i had a chance at a cheap roller cam but it wasnt any bigger than what i have and i would also have had to bought lifters and the keepers. i used a compresion claculator that some one linked to me and it was 9.3 and is now 10.4. i am also going to put a 1" carb spacer on so the heat wont transfer to the carb (its also supposed to help with torque) the next thing that i will have to replace will probably have to be the rear end
Old 05-01-2005, 02:24 PM   #9
72MARIO
72MARIO's Avatar
Thoes heads look sweet.
How do you like the manual brakes. I just picked up my new master Cyl. Kinda hope I don't regret going manual. I have to shoot it with torch red this week.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-01-2005, 02:28 PM   #10
68w/sbc406
68w/sbc406's Avatar
manual 4 wheel drum.......my legs are buff. i have all the disc stuff waiting to go on.
Old 05-01-2005, 10:18 PM   #11
68w/sbc406
68w/sbc406's Avatar
well today wasnt very productive. i had to hit up 2 part stores to find the part i needed to put my temp probe in the head. but i got my headers bolted on, temp probe in, plugs in intake on, dizzy in, carb spacer on, linkage and kick down cable on. now i moved on to the PS pump, it leaks and i bought a alan grove bracket for it so it wont use any head bolts, but i need to drill and tap two holes on the bolck and put the gasket kit on the pump. then hopefully it can go back together.
Old 05-01-2005, 10:32 PM   #12
Randy70C-10
Randy70C-10's Avatar
Nice heads!!
Randy70C-10 is offline   Reply With Quote
Old 05-01-2005, 10:39 PM   #13
68w/sbc406
68w/sbc406's Avatar
thank ya
Old 05-02-2005, 03:21 AM   #14
R@nger
Psalm 23
R@nger's Avatar
Very nice.
Good lookin engine compartment.
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD.
"Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy
R@nger is offline   Reply With Quote
Old 05-02-2005, 10:51 PM   #15
mr402
Whooo Hoooo! Looking nice. Can't wait to see it at our next get together.
Enjoying life again. Time to get those big blocks rolling.
mr402 is offline   Reply With Quote
Old 05-03-2005, 12:29 AM   #16
68w/sbc406
68w/sbc406's Avatar
just more gizmos and gadgets. thanks guy
Old 05-04-2005, 01:11 AM   #17
68w/sbc406
68w/sbc406's Avatar
well this PS pump is kicking my @$$ i bought aftermarket brackets for it and a seal kit since it leaks like a pig. well it was fun puting the seal kit in (not that hard) but then i put it back together and realized i needed to drill a hole in the case to get access to another threaded hole on the pump inside, well with the new "O" ring the pump did not want to come back apart. once i got it all back apart got the hole drilled and put today i started messing around with the brackets and tapping the block so it could be bolted on.then realized that my valve covers BOTH have a big hole (like where a cap would go but they arent threaded) and a PCV port. so now i have to figure out what to run in all the holes. one will be a PCV and the two big holes will be both breathers probably, but what about the other PCV size hole??? also had to go the the auto store twice to get the right size belt for the PS. and tomorrow i get to go to the dealership to find the gromets and stupid stuff. at this point i am frustrated with all the little issues and you can tell by the way the shop looks.
Old 05-04-2005, 01:12 AM   #18
68w/sbc406
68w/sbc406's Avatar
and more
Old 05-04-2005, 01:38 AM   #19
68plus4sub
68plus4sub's Avatar
YEAH man!! I like those heads as well; very cool. I think maybe I'll take a closer look sometime.....like maybe at your house.......like maybe about 2 in the morning....like maybe with a REALLY quiet air gun!!!!!!! I should get a thread going like this, it's cool. As little as I work on the burb, the thread would be gone in a matter of days!!
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt
2008 Kawasaki Concours 14
1997 Harley-Davidson Soft Tail Custom
1948 Chevrolet Coupe (project)
1972 Porsche 914
68plus4sub is offline   Reply With Quote
Old 05-04-2005, 09:01 AM   #20
68w/sbc406
68w/sbc406's Avatar
we wont have the same valve covers anymore, these are center bolt
Old 05-04-2005, 09:41 AM   #21
silvertonguedevil
silvertonguedevil's Avatar
Nice work! Can't wait to check out the difference!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 05-04-2005, 07:15 PM   #22
68w/sbc406
68w/sbc406's Avatar
nice of you to join us, where ya been?
Old 05-04-2005, 08:16 PM   #23
silvertonguedevil
I'm not sure
-Greg
1974 C20 Cheyenne
Old 05-04-2005, 07:35 PM   #24
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
hey 68w/sbc406, you should post some more pictures of the complete engine with the intake on it. so we can see how nice it looks.
joel
joelboxt is offline   Reply With Quote
Old 05-04-2005, 08:09 PM   #25
72MARIO
72MARIO's Avatar
Have considered Copper collector gaskets ? I have them in my 84 and they are great. No blow out's.
2005 TAHOE DD
