Old 05-03-2005, 02:11 PM   #1
dubie
dubie's Avatar
Unlocking steering column
How the heck would you unlock the steering column without the key? I can't find the key and I need to push a truck out of the way but the column is locked
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-03-2005, 02:34 PM   #2
'70_402
'70_402's Avatar
the only way i know of is break it. or put a jack under the front and lift up both front wheels and then push..
'70_402 is offline   Reply With Quote
Old 05-03-2005, 03:33 PM   #3
fade94
fade94's Avatar
You could pull the wheel and then pull the lock ring. It can be done without the tool to compress the spring to pull off the lock ring, but pain to get back on without the tool.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 05-03-2005, 03:37 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Disonnect the column at the rag joint. Then you can steer by pushing the tires.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
