Old 05-04-2005, 10:09 AM   #1
ronh72c10
DIY Aluminum Hard Line Clamps
Here's how I made a set of aluminum hard line clamps for my tranny lines. The method is pretty low tech, I needed a drill press and belt sander, but I could see it being done with a regular handheld drill and a file or sanding block. These were made to fit a 5/16" tube but with different washers (more on that later) you can vary the tubing size or overall thickness of the clamp itself.
I imagine alot of people could free hand the profile of these clamps, I have no such skill so I used a little trick to make these in a repeatable fashion. Basically the secret of these is to choose a washer that has an outside diameter that corresponds to the curve of the edges and has an inside diameter that is the same size (or smaller) as the tubing you're using.
For these clamps I used 1/4" washers that had an ouside diameter of a little less than 3/4" and had an actual inner diameter of 5/16". There's no reason to use this exact size, for that matter you could use a bearing or "machinist's filing buttons" for this, the washers were low tech and cheap so I used them.
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 05-04-2005, 10:10 AM   #2
ronh72c10
I bought some aluminum flat bar 1"x3/8" by about 24" long, it cost about $8. If you don't want as deep a clamp you could certainly go smaller than 1". 3/8" is the critical dimension since it is approximately 1/2 of the 3/4" washer diameter. You don't want to go much thicker than 1/2 the diameter of the washers since you just end up sanding it off and that gets tedious.
Cut two pieces of bar approximately 1-1/2" long, mark a spot centered in the top piece and drill a 7/32" hole (1/4" tap size) through both keeping them clamped down and aligned. Too make it easier to bolt together I tapped the bottom of the clamp for a 1/4" screw. The top was drilled out to 1/4" and then counter sunk enough so the head of the bolt I used was below the surface of the top, I also cut the screw down such that it didn't protrude out the bottom. Dont' forget to deburr all holes so things clamp together tightly.
72 GMC 3/4ton 4x4
Old 05-04-2005, 10:10 AM   #3
ronh72c10
Bolt the two pieces tightly together and mark on the side where you'd like the tubing to go through, use the washers as guides for a good location. Clamp the pieces in a vice and drill the holes, aiming for the seam between the two pieces, make sure to start out with a small drill bit and work your way up to the final size. (5/16" in my case) Deburr the holes from either side.
For the first two clamps I made I actually seperated the two pieces and used a file to make a groove to guide the drillbit, I tried one without doing this and it turned out fine, your mileage may vary.
72 GMC 3/4ton 4x4
Old 05-04-2005, 10:11 AM   #4
ronh72c10
Using a long bolt (5/16"), place alot of washers on either side of the block and loosely bolt them on, the washers should rotate freely but not have alot of side play in them, use another nut to lock the bolt in place while still making sure that the washers can rotate. I used alot of washers because they tend to be slightly irregular, and using alot tends to average out the shape to a rough circle.
Finally using a belt sander I wore down the edges until the washers started contacting the belt, they keep you from going too far since they rotate and as a result wear alot more slowly than the aluminum. I started out with a 60 grit belt and then finished with a 120 grit belt. You don't necessarily need to use a belt sander, you could use a wide file or flat sanding block, just always go in a direction such that the washers will rotate.
After the shape was pretty much done I took the washers off and knocked down all of the sharp edges.
Polish and you're done. One note on polishing I used a green abrasive, but didn't wear a face shield, by the end of the evening I looked like Herman Munster. Use a face shield!
Also I decided to only use the halves to hold the tubing against the frame, but if you use the two pieces together you may have to sand the inner surfaces to clamp the tubing tight.
This should be adaptable for almost any size of tubing, you could also use this technique for more than two tubes. Have fun!
72 GMC 3/4ton 4x4
Old 05-04-2005, 11:38 AM   #5
XXL
Señor Member
XXL's Avatar
Looks like a FAQ post to me. (headed to store to buy aluminum...)
XXL is offline   Reply With Quote
Old 05-04-2005, 01:17 PM   #6
boraxman
Keepin an eye out
boraxman's Avatar
Nice job
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 05-04-2005, 04:54 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-04-2005, 04:57 PM   #8
tnblazerk5
User #12137
tnblazerk5's Avatar
ok i will be doin this soon and i might make me sum heater hose ones too
tnblazerk5 is offline   Reply With Quote
Old 05-04-2005, 05:30 PM   #9
chief bobber
Sanity is a state of mind
chief bobber's Avatar
First rate work! I think you did a beautiful job of custom fabricating these pieces, but I think you need to take it just a tad further to avoid the reaction between aluminum and the steel. You need to insulate between them some how. Even a coating of some kind will work. Anything to create some kind of barrier between the two metals.
Keep up the good work, KC
67 K-10 8ft step 250/465/timken 4 shaft/373 to 1
70 C-10 Panel Vortec V/5spd BW od /307 to 1
70 C-30 9ft stepside dump 350/465/ posi
and a few too many other trucks, cars, jeeps, cruisiers, and M/Cs
...o~`o
chief bobber is offline   Reply With Quote
Old 05-04-2005, 07:09 PM   #10
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Nice Work Ron!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 05-04-2005, 08:17 PM   #11
71Shortbed
71Shortbed's Avatar
Wow. Those are nice. You've got too much time on your hands.
71Shortbed is offline   Reply With Quote
Old 05-04-2005, 09:31 PM   #12
krue
Designated A-hole!
krue's Avatar
I'll see if I can get it moved to FAQ.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-04-2005, 11:08 PM   #13
ronh72c10
A couple more variations on the same idea I made tonight. Both are 1/2" deep.
I agree about the galvanic corosion problem, I'll repolish them and then power coat them with some clear.
I definately don't have too much time on my hands, I just can't prioritize.
Ron
72 GMC 3/4ton 4x4
Old 05-04-2005, 11:36 PM   #14
TugOwar
Very cool stuff!
TugOwar is offline   Reply With Quote
Old 05-07-2005, 03:49 PM   #15
72MARIO
72MARIO's Avatar
Thoes will work well with my stainless lines. another 10 hours of work building clams ahead of me.
Thanks for the great idea.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-07-2005, 06:44 PM   #16
LONGHAIR
You would have to experiment a bit to work out a suitable size drill bit, but putting an o-ring around the line (before the clamp) will stop the electrolysis.
LONGHAIR is offline   Reply With Quote
