05-05-2005, 11:38 AM | #1 |
Lovin' Arizona Since 1961
To Serpentine or Not?
Got all the pulleys, etc. with my 4-bolt 350, but before going this route, thought I'd ask you guyz why would YOU switch to a serpentine belt setup if you could and had all the stuff?
"Religion is like a toothbrush: Everybody should have one, but I don't want yours" - Will Rogers |
05-05-2005, 11:43 AM | #2 |
We did it on my bro's truck, sweet setup, wish I had it. His is GM from a 92 2500. Changed the fitting on the back of power steering pump & used the OE hose for 69. Alt puts out all kids of power. Had to have OE AC line redone by local hose man, he TIG'd another suction connection. Need reverse water pump & fan or go to electric fan. Brian
05-05-2005, 11:47 AM | #3 |
Confirmed Truckaholic
I would never switch, I personly don't like the look. But that's just my opinion.
05-05-2005, 11:49 AM | #4 |
Keep On Truckin'
I did switch and didn't have all the stuff, had to hunt it down and buy it. I switched to update the performance and look of the engine since I'm running a TPI setup.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-05-2005, 11:53 AM | #5 |
Lovin' Life in Miss.!
I switched. Trust the serpentine more n the belts. CS-130 alt was nice too.
The truck... you hear that? No really, you did hear that?!!! |
05-05-2005, 12:41 PM | #6 |
More Cowbell....
I did it....and L-O-V-E it. Plus, it looks pretty cool, too.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
05-05-2005, 12:48 PM | #7 |
Just Don't Stop!
v-belts don't seem to stay on as well at 6,000+ rpms...
1968 C10 build in process TT LSA/6L90e/9" |
05-05-2005, 12:58 PM | #8 |
I've been thinking about it to get rid of that 9 mile long ac compressor in favor of the newer round unit and get the alt out of the way for some taller valve covers.
I've been thinking a 4.3 would be a good donor but wonder what others are using ?
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page |
05-05-2005, 01:24 PM | #9 |
my gas saver
a 4.3 will work just fine. the one putter has posted above is from a 4.3 you also don't have to worry about adjusting the belts just right. say goodbye to whining and squealing belts too. if you run big power like i had in my 66 chevy 2, you'll almost definetally sling a belt when you crank 8 grand on the tach.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
05-05-2005, 02:03 PM | #10 |
'Burban Legend
BB and Roots type supercharger?
Has anybody done it with a big block? To go one step further, how about with a blower? I would be very interested to talk to THAT guy (or gal)! Would like to eliminate all factory brackets and get a complete setup compatible with my WEIAND SC. Any chances at all? Hot Rod
05-05-2005, 02:11 PM | #11 | |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 05-05-2005 at 02:11 PM. |
05-05-2005, 02:29 PM | #12 |
my gas saver
my neighbor has a blower on his car and i bet that belt is a good 3" wide.
you can get a big block serpentine set up. "harold shepard" has one on his truck.
05-05-2005, 08:52 PM | #13 |
v- belts may come off at high rpm (mine do) but when you loose a serp. belt you loose everything including the waterpump i.e. no limping home
05-05-2005, 09:20 PM | #14 |
but you wont ever lose a serp belt unless something drastic happens or your too lazy to do maintenance and your running a dry cracked belt.even if a component locks up on a v belt system you can lose all your belts if say a water pump goes or something of that sort but yet again if you maintenance and check things every once in a while a bad bearing will be a noisey bearing before it locks up
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
05-05-2005, 09:26 PM | #15 | |
05-05-2005, 11:50 PM | #16 |
'Burban Legend
Seperate Belt
Yeah, the roots type blower has it own seperate belt, but it is not like a 6-71 style blower. It is a very low profile (underhood, '70 Chevelle) and the belt is much narrower, but I need a setup for the rest of the components. Maybe I will try to PM Harold on what he went with. Thanks folks, Hot Rod
05-06-2005, 12:23 AM | #17 |
got boost?
but you won't ever lose a V-BELT unless something drastic happens or your too lazy to do proper maintenance & your running a dry cracked belt.
see how that sh*t works cableguy0? a properly aligned v-belt system with pulleys & brackets designed to handle 8000 rpm will not come off at 8000rpm.racers have been using them for years. i personally have seen serpentine systems come off at 6k rpm. fact is, it wasn't designed to handle the forces imparted on it at that rpm! if you plan to turn such rpms, get a setup designed for it.don't watch a stock or "looks good" setup fly apart & then talk trash on it because you pushed it beyond it's design limits. as for my opinion;for the street the serpentine setups have proven their reliability.they seem to be more efficient & have better traction on the alternator. install it right,carry a spare belt & enjoy the benefits. for high rpm applications you better have a system designed for it. for noob:http://www.jiffylube.com/HowCarsWork...entinebelt.htm
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" Last edited by CHEVIBUBBA; 05-06-2005 at 12:36 AM. |
05-05-2005, 11:57 PM | #18 |
i`ve got v belts still,a 120 amp cs-130 alternator,gates belts,ran it 6-6500 rpm several times,street and strip,and never thrown the belts.i`m happy
05-06-2005, 12:00 AM | #19 |
Psalm 23
Hehe ok I have a question...what is a serpentine belt?
And yes you can call be a n00b .
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
05-06-2005, 12:54 AM | #20 |
Psalm 23
Hehe ty sensei!
05-06-2005, 02:35 AM | #21 |
nahh i change my v belts every 5-8k miles because i wring them off and shred em going 6500 all the time. its proven a v belt will shred around 6500 rpm. a true RACE car isnt seeing any street miles and if it is they are minimal. whats run at the track and whats run on the street is two totally different things. there really arent any benefits to a v-belt except maybe slippage and constant adjustment needed.if v-belts were so great they woulda never stopped running them on modern vehicles
05-06-2005, 07:16 PM | #22 | |
got boost?
as for true race cars;#1:1000 race miles are equivilent to 10000 or more street miles. #2would you consider a 10 second sedan a true race car? i do!& so do the one's being spanked by it at the track.it is of little concern that it runs those times with bfg ta radials, drives to the track at ennis & home to corpus christi & is tagged & inspected. whats run at the track usualy is what is run on the street.just a few years later.it's called r&d. most manufacturers subscribe to this using factory teams to learn how to make their stuff better, stronger & sometimes faster. the benefit of v-belts; 1: they are cheap 2:they work. 3:unless you lose the water pump or crankshaft, when one accessory fails, the others continue to operate.it's called redundancy. 4:a v-belt setup is lighter. 5:tensioner?i don't need no stinkin' tensioner! 6:less moving parts.
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" |
05-06-2005, 09:40 AM | #23 |
I want to do it as long as I can keep my alt on the drivers side.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
05-06-2005, 10:17 AM | #24 |
More Cowbell....
Well, if we all agreed and ran the same setup....we would all run the same speed, get the same gas mileage, and be bored to tears.
We gripe when we are the same & then gripe when we differ. I run what I run because it is what I want. I like to see different setups and find out "how" they perform. Bottom line, if YOU like it, run it. Did I mention that this is a GREAT BOARD?!
05-06-2005, 11:15 AM | #25 |
Got Big Block?
I've been very please with my psuedo serpentine setup. I think it's off an 86 or 87 1 ton.... serpentine belt for the crank, alt, and waterpump. v-belt for the power steering. haven't had a problem yet, with many bursts around 6500...
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 05-06-2005 at 11:24 AM. |
