05-05-2005, 06:58 PM | #1 |
converting from 1-1/4" to 1" rotors
I am considering changing the front brake rotors on my '77 to the later 1" thick ones in order to use the BelTech spindles I already have. Am I for doing this? Are the 1-1/4" brakes significantly better? Should I spend the $280 and get the right spindles? Anyone have a set they would trade?
- Greg |
05-05-2005, 07:42 PM | #2 |
I have 1 1/4" and can stop nicely, I can't really compare to the 1" rotors though. It is considered the heavy duty option for the breaks so somthings gotta be better. Possibly at dissipating heat.
Instead of spending $280 in spindles, you can spend $220 for DJM's 3" spindles. |
05-06-2005, 08:50 AM | #3 |
I converted to 1 1/4" rotors from 1" when I installed drop spindles. I noticed some difference, but not a huge amount. The worst part of the deal is the cost, you will have to replace rotors, inner and outer wheel bearings, and calipers. I also replaced the brake hoses and pads, because they were shot.
05-06-2005, 12:36 PM | #4 |
Mudslides 'r my specialty
Why not sell your spindles and buy the correct ones for the 1 1/4's.
I can't see spending money to downgrade your brakes just to look cool.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
05-06-2005, 12:55 PM | #5 |
yeller
I would personally keep the bigger rotors and buy the right spindles. Sell the other spindles, either here or on Ebay. You may lose a little money on the deal (maybe, but maybe not), but with a big block and the possibility of using it for towing...keep the bigger brakes.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-06-2005, 01:19 PM | #6 |
im fixin to go from 1 inch on my 78 to 1 1/4 and i have all the stuff i need to do the change over i got a 82 with 20,xxx miles so i got some basically new frt end to swap
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
05-06-2005, 07:11 PM | #7 |
Thanks for the feedback. I'm going to follow y'alls advice and stick with the 1-1/4" rotors.
- Greg |
