Old 05-08-2005, 11:53 PM   #1
PMS
1/4 time - speed
Any idea what a 72 long bed with a 330HP / 380TQ 350CID with a 2500 stall converter, turbo 350, 3.42 rear with 28" rear tires might run in the 1/4?
Thanks,
Parrish
PMS is offline   Reply With Quote
Old 05-09-2005, 12:44 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
it would depend on the conditions. but just to let you know when i tried to run my truck at the local track they wouldnt let me cause of the gas tank in the cab
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-09-2005, 10:54 AM   #3
Purs
Got Big Block?
Purs's Avatar
to many variables but I'll take a stab, mid to low 14's at 95mph.
sorry to hijack but has anyone else had this trouble with not being able to run with the tank in the cab? 68w/sbc406, was this an IHRA sanctioned track?
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 05-09-2005, 05:06 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Never heard of that one before
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-09-2005, 07:48 PM   #5
68w/sbc406
68w/sbc406's Avatar
thats the stupid part. it wasnt an IHRA sanctioned track but they were using IHRA rules (this was at PIR for the locals) its a road course that the CHAMP cars run at and then during the summer they have the friday night drags. its a ****hole of a strip anyway. people are always fighting to get traction.
Old 05-09-2005, 11:46 AM   #6
bowtie
bowtie's Avatar
1/4
I ran 11.7 w/juice and 12.7 without, and my tank is still in the cab.
My guesse would be high 14's to low 15's @ 90mph.
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
Old 05-09-2005, 11:55 AM   #7
redhead69
fugedaboutit
redhead69's Avatar
thats why I'm doing my swap.. lots of friends at Woodburn Drags.. (IHRA) and they are very strict about that tank in the cab.. had a friend who kissed some butt and they let him run for the day.. as long as he didnt go under 14.00 in the 1/4. If they do let you run they will haggle you all day. I think the swap will help with traction too!
redhead69 is offline   Reply With Quote
Old 05-09-2005, 08:19 PM   #8
minibike
minibike's Avatar
I would guess in the high 14's or low 15's, if the horsepower numbers are Dyno'd and accurate. I have 350HP at the flywheel...maybe 300 at the wheels on a shortbed. Before posi, I couldn't run better than a 14.72 at about 92 mph. After posi, the best run was 14.14 at about 97 mph.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 05-09-2005, 11:31 PM   #9
racer6
my 67 lwb, with battery and fuel in bed, powered by a 327cid/350hp to rear wheels, 373 posi, 400 torbo w/ 2500 stall runs 13:20's in 1/4 and 12:60's in 1000'.....it weights 3850 with me in it...............if that helps
racer6.. slightly burned out, but still smokin'..
racer6 is offline   Reply With Quote
Old 05-10-2005, 12:23 AM   #10
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
these guesses seem optomistic to me.
on 28's i "guess" 15.3-15.7.
i never had a problem at ennis with the tank in the cab.they are nhra track.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 05-10-2005, 09:17 AM   #11
bigjimzlll
bigjimzlll's Avatar
put your info into this calc.....its pretty close.
http://www.wallaceracing.com/et-hp-mph.php
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 05-10-2005, 11:41 AM   #12
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
that says if my truck weighs 4000 pounds and i make 375 horse i will run...Your ET / MPH computed from your vehicle weight of 4000 pounds and HP of 375 is 12.82 seconds and MPH of 104.49 MPH.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 05-10-2005, 03:50 PM   #13
FirstGen
Just Don't Stop!
FirstGen's Avatar
I think that calculator is a little off, it says I will run:
Your ET / MPH computed from your vehicle weight of 3600 pounds and HP of 600 is 10.58 seconds and MPH of 126.58 MPH.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 05-10-2005, 04:04 PM   #14
bigjimzlll
bigjimzlll's Avatar
You needd to input rear wheel HP...and yse it is accurate if you input correct HP and Weight.
Anderson,CA
Old 05-10-2005, 04:08 PM   #15
cableguy0
its accurate. what that calculator doesnt say is that the numbers are with optimum gearing and a proper setup all the way around on the vehicle. so if you got something like a 3.07 gear and a huge cam its going to be way off.a properly matched setup is what that calulator is going by
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-10-2005, 05:52 PM   #16
FirstGen
Just Don't Stop!
FirstGen's Avatar
yeah my combo is very well matched but I don't see 10:50's with this setup.
I have 458 rwhp on motor, 100 shot (1st stage), 75 shot (2nd stage) with 6 speed standard trans, 4.10 gears, 29" tall tire. Have been 7.0X @ 101 in the 1/8 on first stage...
I think it is probably a close estimate but I think it's a little off...
TT LSA/6L90e/9"
Old 05-10-2005, 05:48 PM   #17
FirstGen
Just Don't Stop!
FirstGen's Avatar
I did input rwhp... I think it's a little off considering the brick aerodynamics of our trucks at 100+ MPH... jmho..
TT LSA/6L90e/9"
Old 05-10-2005, 06:45 PM   #18
bigjimzlll
bigjimzlll's Avatar
mine with with 650RWHP runs 10.59 at 121.9 thats with a 150 shot
Anderson,CA
