Old 05-12-2005, 03:00 PM   #1
ac102nv
ac102nv's Avatar
late model engine swap....
I know this has been discussed before, but... I'm thinking of swaping in a Vortec 350 from a 96-99 truck complete with auto trans, comp, wiring, and...into my '72.
Are there any major hurdles I need to be aware before I start down the path? I did the I6 to BB swap a few years back, so the "normal" issues with the swap are no problem, just looking for the big ones. And if anyone has pics from this swap, I'd love to see them.
Thanks,
'72 C10 lwb 454/TH400
ac102nv is offline   Reply With Quote
Old 05-12-2005, 07:14 PM   #2
HeavyD
HeavyD's Avatar
Vortecs don't use a mechanical fuel pump so an electric one will have to be installed.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 05-13-2005, 02:31 PM   #3
shifty
Questionable
shifty's Avatar
This was covered in last month's issue of Classic Truck Magazine. I ahve a copy and scanned it off for other board members. Because there are so many electronics on the new Vortec engines, you'll need to have someone reprogram all of the equipment. Trying to find someone to do this sounds like a chore.
That's a big decision you've chosen to make!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-13-2005, 02:50 PM   #4
ac102nv
ac102nv's Avatar
Shifty,
I PM'd you for a copy of that article...please.
I know this won't be "easy" but the idea of a daily driver that starts when cold/hot/whatever every time, get's double digit GM, has OD for highway use, etc is too tempting. Besides I have a line on a '69 camaro that could really use my BB .
Thank you,
Old 05-13-2005, 02:59 PM   #5
FirstGen
Just Don't Stop!
FirstGen's Avatar
Originally Posted by ac102nv
Shifty,
Thank you,
You might consider one of the newer vortec motors like the '99+. They are LS1 based motors and perform much more effeciently and are simple to reprogram. Do a search for LS1/T56 for more info.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 05-13-2005, 03:44 PM   #6
shifty
Questionable
shifty's Avatar
Actually, I think ... I think the article I have is from the 99+. Sorry for the misinfo, I'll give you guys the article anyways.
Old 05-13-2005, 04:05 PM   #7
ac102nv
ac102nv's Avatar
FirstGen, would it possible to get a few pics of your setup? I could be persuaded if it's not too tuff.
Thanks,
Old 05-13-2005, 05:40 PM   #8
FirstGen
Just Don't Stop!
FirstGen's Avatar
sure
TT LSA/6L90e/9"
Old 05-13-2005, 06:06 PM   #9
Hart_Rod
Hart_Rod's Avatar
Late model engine/tranny
FirstGen,
I have a 69 Burb that I'm putting a 05 5.3/ 4L60E tranny in and would appreciate any information/pictures. What harness did you use? Who remapped your computer? Were there any clearance issues? What radiator did you use? Do you have the hose part numbers? Wha engine/transmission mounts did you use? What gas tank? Did you use and in tank or inline fuel pump? Are you using factory gauges, if so were there any connection problems? Did you use one piece or two piece drive shaft?
AC102NV,
I picked up an 2005 5.3/4L60E with 10 miles on it. I came with all acessories, mass air flow, 02 sensors, fuel pump module and electric gas pedal for $3350 delivered! I got the motor from Schram Auto parts:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Ask for Jeremy. Tell him Rob Hartley said to call.
Hart_Rod is offline   Reply With Quote
Old 05-14-2005, 01:17 AM   #10
FirstGen
Just Don't Stop!
FirstGen's Avatar
Originally Posted by Hart_Rob
FirstGen,
AC102NV,
Rob,
Sounds like you are off to a great start. Please do a search for LS1 and look for any threads I've posted on. I've covered these issues many times. The starter thread was one titled "LS1/T56".
But here is a quick run down, just note that there are many options I choose this route to best suit my needs.
EDIT: just noticed that it looks like the search is shut down. Maybe someone has it bookmarked...
What harness did you use? built a new one from scratch.
Who remapped your computer? I did using HP Tuners and LS1Edit and I built the harness around a F-body PCM so that I could do this.
Were there any clearance issues? Yes, depending on the exhaust you use and the oil pan. The truck oil pan is the best. I used modified vette manifolds origionally see the mentioned thread above for pictures.
What radiator did you use? a new '68 C10 radiator
Do you have the hose part numbers? 2000 silverado upper/lower rad hoses see dealer or ebay.
Wha engine/transmission mounts did you use? I made my own engine mounts similar to the ones S&P sells for the motor and made a custom tubular crossmember and teflon mount for the T56.
What gas tank? Summit 16gal with foam and GM 0-90ohm fuel sensor
Did you use and in tank or inline fuel pump? inline Aeromotive A1000 fuel pump and aeromotive regulator (950 hp capable)
Are you using factory gauges... Autometer guages. You will not be able to use a stock speedo since it is mechanical and you will have an electrical VSS output. You can buy a converter that will cost you the price of an autometer tach and electric speedo if you really want to.
Did you use one piece or two piece drive shaft? one piece, first one was aluminum and supposedly bulletproof. well it didn't last long with slicks, now I went to steel would have been much cheaper to do this first off.
Good luck!
TT LSA/6L90e/9"
Old 05-13-2005, 07:06 PM   #11
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
firstgen....how many miles does your motor have on it?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 05-13-2005, 07:58 PM   #12
ac102nv
ac102nv's Avatar
Hart_Rob....now you're trying to make me feel bad. That looks like a screaming deal on the engine!! With 10 miles it must have fallen off the transport Keep us posted as to the progress. I want to do this, but I'm not 100% commited...yet.
FirstGen...looks great! I would also be interested in the answers to the questions above, most importantly mounting/headers/guages.
Thanks all for the info.
Old 05-14-2005, 01:18 AM   #13
FirstGen
Just Don't Stop!
FirstGen's Avatar
I bought it from a salvaged vehicle with 2700 miles.
TT LSA/6L90e/9"
Old 05-14-2005, 09:21 AM   #14
Hart_Rod
Hart_Rod's Avatar
Swap
FirstGen,
Thanks for info, I'm sure I'll have more questions as I progress.
Rob
Old 05-13-2005, 09:20 PM   #15
1978steven
1978steven's Avatar
There is a lot of good info here:
http://www.ls1tech.com/forums/index.php?
In fact here is a small post I found about LS1's in 67-72 trucks:
http://www.ls1tech.com/forums/showthread.php?t=314955
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 05-13-2005, 10:30 PM   #16
Hart_Rod
Hart_Rod's Avatar
Engine
AC102NV,
You must have ESP! It was damaged during transit. I plan on taking a lot of pics as I go. I'm baggin it also.
Rob
Old 05-14-2005, 11:16 AM   #17
FirstGen
Just Don't Stop!
FirstGen's Avatar
No problem, it is really a pretty direct swap. Everything seems to add up quick though $$$.
Let us know how it turns out!
Take care.
TT LSA/6L90e/9"
Old 05-14-2005, 11:45 PM   #18
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
that auction stated that it had less than 100 miles in it. i think hart rob must have missed a 0 in that post.
joel
joelboxt is offline   Reply With Quote
Old 05-15-2005, 08:07 AM   #19
Hart_Rod
Hart_Rod's Avatar
Engine
JB,
I didn't get the engine off of Ebay, I was just watching the action. After it was over I called them and bought one. The vehicle it was in was damaged by the transporter. Can't wait to get started, I'm baggin next weekend. Hopefully the motor within a couple of months.
Rob
Old 05-15-2005, 01:18 PM   #20
joelboxt
joelboxt's Avatar
Hart rob,
alright i understand sorry about that.. thought that was the auction you won.
i think that would be a decent swap. if i had unlimited funds id be doing something like that also.. i know in canada if a GM vehicle gets damaged during transport they are given to the collage's for the students to learn on. must be different in the US.
joel
Old 05-16-2005, 07:30 PM   #21
Hart_Rod
Hart_Rod's Avatar
5.3l/4l60e
Pics of the suburban engine and tranny came out of.
Rob
Old 05-16-2005, 08:20 PM   #22
67ChevyC10Stepside
what happened to it? they dented the door in so they scrapped the entire 40000 dollar vehicle?
Old 05-16-2005, 08:38 PM   #23
Hart_Rod
Hart_Rod's Avatar
I guess the transporter messed it up. I agree, crazy to scrap a new vehicle (although I'm not complaining). I'm sure GM will write it off or raise the price of the 06's!
Rob
Old 05-16-2005, 09:23 PM   #24
shifty
Questionable
shifty's Avatar
I haven't forgotten about the scans, y'all.
And I wish I could score a new engine-tranny combo like that around here in GA. I mean, I wouldn't want the same one, but I'd love to find a place with scores like that.
Old 05-16-2005, 10:42 PM   #25
Tim240Z
Tim240Z's Avatar
I have just completed the conversion of a 99 suburban L31/4L60E (Vortec) into my 71 C20.
Not a big deal. If you search through some of my posts (not too many) you can find some info. If you need specifics, let me know.
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
