05-12-2005, 04:19 PM | #1 |
Senoir Member
67 K10 suspension lift question
What is different about the 67/68 4wd front axle & springs when compared to a 69-72 4wd. I want to remove the rough riding make-shift lift that is on my 67 K10 truck, but most places don't carry a lift for the 67/68. One place said the spring mounts were in different places and the springs were different lengths. I will probably add a 71 or so front axle to get the disc brakes and power steering. Any ideas or suggestions....PLEASE
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
05-12-2005, 04:56 PM | #2 |
Mike
Front springs are the same.Rears are different.You could use blocks in the rear,or change to newer hangers.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
05-12-2005, 06:20 PM | #3 |
It's not too hard to move the rear spring hangers. Just measure the difference beteween the old and new springs and move the mounts accordingly. Chris
05-13-2005, 06:35 AM | #4 |
Senoir Member
I was planning on using the 4" blocks in the rear. How can I tell if the rear has an add a leaf, since the current block is only 2"? Would I have to move both hangers for each rear spring? Thanks
05-22-2005, 02:04 AM | #5 |
I need another Barley Pop
Yes, you would have to move both spring hangers for each spring as the axle centering pin is dead center on the 67-68, and offest on the 69 and newer. You will only need to do this if you want to center the rear tire in the wheel opening. I opted to have rear springs made but it wasn't cheap.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" |
