04-12-2002, 12:00 PM | #1 |
faster, faster, faster
Rear drum lock up, HELP !!!!!!
I just replaced the right rear drum, and cylinder. The problem I am having is that after a few miles of driving and use it feels like I am driving with the parking brake on, and the brakes smell and smoke really bad. When they cool down they are OK again. Did I adjust the brakes too tight, or is there another problem?
I'm going to Law School, wanna debate? It's good practice. |
04-12-2002, 12:19 PM | #2 |
wheel cylinder needs replaced, or parking brake cable is stuck and frozen
good luck ------------------ ------------------ Randy- Lincoln, IL r68c30@hotmail.com -71 C-10 350/CH465/3.07 12 bolt 3.07/ trying to assemble! *Life and time permitting* :P -84 Z28 Camaro 5.0L 700R4, 3.73 rear -84 Firebird SE 2.8L. 5 speed Borg Warner -82 Firebird 350/TH350 *parting out 5.0LTPI '81 cutlass supreme brougham, and have lots of '67-87 parts of all kinds to sell or trade* *Paint is overrated © RSS Enterprises 2000 |
04-12-2002, 12:47 PM | #3 |
Wheel cylinder is brand new. Brake cable is not frozen. I checked that first. I bled a little from the line with no pressure on the peddle. Took it for a spin, and the problem seems to be solved. The brakes are a little softer, but still work well. I guess they don't need to be as tight with the power brake system. I hope this was a permanent fix though, we'll see.
04-12-2002, 01:07 PM | #4 |
odd..... soft means air in cylinder or lines or master cylinder. typically
good luck |
04-12-2002, 02:27 PM | #5 |
They might be too tight. Jack up the back and turn the wheels by hand. You should get about only one full revolution out of the wheel before friction causes it to stop.
But drums never were the greatest for getting rid of heat. ------------------ Southpa 1970 GMC 1500 Custom Victoria, BC, Canada
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
