Old 05-16-2005, 11:33 PM   #1
HeavyK20
HeavyK20's Avatar
Eaton to 14 Bolt Swap?????
I'm want to change from an Eaton to a 14 Bolt rear. I am wondering if my driveshaft length will have to be adjusted. Does anyone know if the pinion yoke position is the same between these two units?
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 05-17-2005, 06:09 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have no exact measurements but I believe the pinion is lower and the yoke sticks out further than the eaton. I know the dana 60 pinion in my gmc sticks out further than the eaton pinion in my chevy.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-17-2005, 08:18 AM   #3
HeavyK20
HeavyK20's Avatar
Thanks for the input. I have a 60 core and it looks like the driveshaft would have to be shortened going from Eaton to a 60. I was hoping that the 14 bolt would be close enough to the Eaton that I would not have to jack with the driveshaft.
Eric
Old 05-17-2005, 05:21 PM   #4
ryanroo
ryanroo's Avatar
if i remember correctly when i did the swap, it shortened the driveshaft, i just ahd a machine shop cut the weld off and cut he tube then reweld the yoke on. spent like 15 bucks. i know for a fact that the 14 bolt pinion is alot farther away from the rear output that a dana 60 rear, i just did that swap like a month ago. my driveshaft still worked, but i had installed a longer tranny/tcase so yours might not.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
