Old 05-17-2005, 02:09 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Radiator Problem
My radiator leaks so badly now that when I fill it up that it will pour out with a stream that is a little bigger than an 1/8" in diameter. Obviously it doesn't take very long to drain and it is inside the four-core about one third up from the bottom. Is this terminal? Should I take it to some one to fix or go ahead and cough up the $180 for a new one?
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 05-17-2005, 03:07 PM   #2
ryanroo
ryanroo's Avatar
um... around here(creston IA) its free to have them look at it and tell you if its ruined or not, so i would take it in. chances are that if it is that big of a leak and nothing was pushed through it, then it is bad, probably rotted through. where are you looking for a replacement?
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-17-2005, 03:08 PM   #3
smokekiki
Mike
smokekiki's Avatar
What caused the hole?If it is corrosion,I would look into another one.I don't know what it would cost to rebuild.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-17-2005, 03:45 PM   #4
cadiac
I have a 3 row I would sell "cheap" if you can wait till the 27th, -will meet someone there (Des moines) to pick up a truck. If not -ok -I just have a few sitting around probably to good to scrap.
cadiac is offline   Reply With Quote
Old 05-17-2005, 05:32 PM   #5
70c10
67-72 Addict!
70c10's Avatar
I just bought a 4 row off ebay for my dads truck brand new with a lifetime warranty for $138 plus $15 shipping. Took 2 days to get it. I just called the number in the auction with a credit card. The company has them on there everyday. Here is the link:http://cgi.ebay.com/ebaymotors/ws/eB...category=33602.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-17-2005, 06:26 PM   #6
farside847
farside847's Avatar
I got one from them too. Worked great. I tend to have the "screw it, get a new one" personality though...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 05-17-2005, 06:16 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
There is a product called Bars Leak that has worked for me to stop leaks in the radiators. There are others also but that is the one that comes to mind.
If the radiator is corroded then a new one is in order. Being inside the outer row of cores makes me wonder what caused the hole. It is possible to pull that tube and solder the openings in the top and bottom tanks. You lose one tube and maybe the one on the outside of it but with a four core that won't affect cooling capacity.
Find out what caused the leak and go from there.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-17-2005, 06:30 PM   #8
cadiac
Curious -What brand are the radiators they are selling on Ebay? A good price for a 4 row around here is about $150.
Old 05-17-2005, 09:13 PM   #9
71Shortbed
71Shortbed's Avatar
The one I got off ebay was a 4 row Modine with the heater outlet. Paid about 135 and they brought it to my house for 15$. Came from radiator.com or radiator express.
71Shortbed is offline   Reply With Quote
Old 05-17-2005, 09:35 PM   #10
JayDubBlazer
go cyclones
For that price I think I will go with a new one, It is over thirty years old so it probaly be best to just get a new on. The leak started small and then got bigger so I would assume errosion.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 05-17-2005, 09:38 PM   #11
JayDubBlazer
go cyclones
oh and thanks for the info
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 05-17-2005, 09:43 PM   #12
71Shortbed
71Shortbed's Avatar
They originally sent me a 3 row without the heater outlet. It was a cheap one made in Brazil or someplace. I called them and told them I needed the heater outlet and they sent the really nice 4 row Modine. No extra charge. Just something to be aware of. They are really easy to deal with.
Old 05-17-2005, 10:09 PM   #13
cadiac
I have bought Modines and GoDans (spelled right ??) and had all Good luck.
Old 05-17-2005, 10:25 PM   #14
CAJ68
for all you guys with no money for a new radiator or to pay to get one fixed. i had a rock go through mine once. i filled the hole with rtv sealant and put in a can of black pepper. drove for another 2 years. poor boys got poor ways
CAJ68 is offline   Reply With Quote
Old 05-17-2005, 10:45 PM   #15
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Yes The www.radiator.com people are very easy to work with. thats where I bought my 4 Core at for cheap and have not had one problem with it. as far as the bars leaks and the pepper trick goes these should be used as mere quick fixes until the problem at hand can be fixed. These items build up to clog the hole but also build up in other areas you don't want them.
WRMZ71 is offline   Reply With Quote
