Old 05-18-2005, 01:31 PM   #1
special70gmc
special70gmc's Avatar
what causes this?
what causes the grear on the distrubuter that meets the cam to strip out?
my engine died on me like 2 weeks ago ans i just pulled the dizzy out and found the gears on my msd probillit dizzy rounded over (that must be the problum duh ) so how does this happen and is my cam ok? is the rest of my $6000 motor at risk? or should i change the oil and try to forget it happened? thanks -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 05-18-2005, 02:32 PM   #2
StingRay
StingRay's Avatar
What kind of cam do you have? A roller cam with a steel gear will eat up a dizzy gear. You need a bronze gear with a roller cam. Likewise a bronze gear on a cast cam might not be the ideal combo either.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 05-18-2005, 03:02 PM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
If you destroyed the dizzy gear and all the metal is in the engine you had better tear it down and do an inspection before you risk more damage.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 05-18-2005, 03:21 PM   #4
kxmotox247
kxmotox247's Avatar
Yeah... what he said. I just bought a new GM distributor from a guy who wasn't able to use it. It came in a new gm crate motor with a roller cam. It's a $300 distributor but it has the special gear. I called my machinist to ask if I could use it with my cast cam and he said heck no. But he said to buy it anyway and we'd get a different gear for it. This was all news to me yesterday.
Here's the special gear for roller cams and the distributor I bought. I'm pretty sure you cam buy aftermarket gears too. Don't know if the price is any better or not.
http://www.flatlanderracing.com/distgmbb.html
kxmotox247 is offline   Reply With Quote
Old 05-18-2005, 08:42 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Summit sells a bunch of them. Looks like they start at about 35 bucks.
CLICK HERE
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-18-2005, 09:19 PM   #6
special70gmc
thanks everybody i pulled the cam today to check it out and it seems ok but im going to replace it anyway with a bigger solid lift cam the old was hydrolic flat tappit but i need to figure out what went wrong so it doesnt happen again it looks like the gears werent meshing corectly because all the teeth are worn on the front edge to a point untill the one side of the dizzy teeth snaped and broke off ill post pics tomarrow, but i was thinking that maybe since i put the new intake on 2 months ago that the hight of the ditributer in relation to the cam is wrong? causing the mesh to go wrong maybe? ill have to wip out the ruler and figure out is the dist ride height is correct thanks -kyle
1958 belair 2door
Old 05-19-2005, 05:30 AM   #7
4x4Poet
Does all that mean that the dist gear material matched the cam after all?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
