Old 05-19-2005, 06:28 PM   #1
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Driveline carrier bearing
I remember people talking about carrier bearings but I can't seem to find the search function.
I keep having to replace mine. I have a feeling it's an installation issue. Is there a trick to getting them in there just right so they don't go bad in a couple months?
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 05-19-2005, 08:08 PM   #2
Maximum Overdrive
December 21, 2012
Take it to a machine shop and have it pressed on by them. Also you might make sure your driveline is balanced as an unbalanced driveline will tear a bearing up pretty fast. Prices will vary from place to place but here I got the bearing pressed on for $10.00 and the driveline balanced for $30.00. Probably higher now. I havent had a problem with it sense and its been probably over 12 years now. At one point I was going through a bearing every couple of years.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 05-19-2005, 08:16 PM   #3
neonlarry
neonlarry's Avatar
The other possibility is the rear is not centered. That was what caused mine to go out the first time (PO put front coils on the back, raised it a good 3"). When I put the rear back together I put in a billet one from DLS.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-20-2005, 11:29 PM   #4
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Thanks for the advice. A guy at the parts store suggested that it could also be the tailshaft bushing in the tranny. I'm told they rarely wear out, but I did have one go bad on me in a previous Chevy vehicle.
