wanted: blazer X member
it is a 79 k5 and i need the X member that holds the trans/t-case up it is not a devorced case......and if you have it i would like to have the bushings that go in between the X member and the trans....Thank's
Dan. 55 F100 panel truck project 64 ![]() 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 ![]() 83 ![]() 88 ![]() ![]() 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops ![]() ![]() ![]() ![]() ![]() |
know if a crossmember from a 465/205 setup would work? i've got a spare if it will.
no i deal maybe some one else could tell?..................anyone?
bump....anyone know if his X member will work for what i'm wanting it for?....
i'll post up on CK5 and find out.
Junior Member
![]() Join Date: Dec 2004
crossmembers are different depending on the setup. What tranny and transfer case do you have?
i will be using a th350/np203
Would it be different than a Suburban?
I have one on my '79 1/2ton Sub', t350, not sure of transfer case (cast iron case).
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
I like cheese
I've got a crossmember from a 78 K5 that had a Th350/NP203 in it. Let me know if your interested. $25 plus shipping.
Cruiser: 1972 K5, 400/TH350/NP205, D44 and 12Bolt, 35 TSLs. Trail rig: 86 K5, 350 TBI, SM465/NP205, 5.13s, 14ff locked, h1 beadlocks, 42" TSLs, 64" rears, 56" fronts, D60 locked, 35pline, drive flanges, crossover, hydro assist, OBA. Tow rig: 2002 F350 PSD CC Dually FX4, chipped, cold air intake, BFGs |
