Old 05-21-2005, 05:07 PM   #1
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
heater hose routing
After 15 years of being apart, I'm having a memory lapse on how the heater hose routing is supposed to be on my 71.
I have a fitting in the intake, the water pump and a fitting in the radiator.
The one picture that I can find has the upper heater fitting going to the radiator and the other going to a tee that fed an inline coolant heater but I can't tell where it connects at the engine.
My 69 396 has a conventional setup with one hose going to the intake and one going to the water pump. I can't find anything in the assem. book showing the extra radiator fitting.
Any pictures or recommendations would be appreciated.
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 05-21-2005, 05:36 PM   #2
john
member #16
john's Avatar
The 5/8" hose should go from the intake man to the lower heater inlet, the 3/4" outlet should go to either the water pump or rad, depending on year model. John
john is offline   Reply With Quote
Old 05-23-2005, 03:41 PM   #3
HugrOrang71
Bite me, import boy
Thanks for the reply.
Jason
