05-21-2005, 06:30 PM | #1 |
Keep On Truckin'
CS130 Alternator wiring question
Has anyone installed a CS130 alternator (later model GM) and if so how did you wire it up? I have no idiot light for the alternator.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-21-2005, 09:02 PM | #2 |
The battery wire should be obvious. The S terminal isthe voltage sensing wire, hook the to the origional buss bar(red wires on DS fender well). The L terminal goes to a switched ignition source THRU A 35-100ohm 3+watt resistor. This circuit needs this resistor to keep from frying the electronics in the Alt.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-21-2005, 09:12 PM | #3 |
Its a Truck Thing......
So if you have the light do you still need a resistor?
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
05-21-2005, 11:15 PM | #4 | |
Keep On Truckin'
05-22-2005, 10:51 AM | #5 |
what about if you are using a voltmeter, would that act as the resistor?
05-21-2005, 09:37 PM | #6 |
^ no, use the light in place of the resistor.
05-22-2005, 11:20 AM | #7 |
^No.
05-22-2005, 06:34 PM | #8 |
Keep On Truckin'
I found a pigtail with the correct resistance in the wire that AC Delco makes for this; part # 8078 and cost $21.88 from Advance Auto parts.
05-22-2005, 10:11 PM | #9 |
Thats good to know, a lot of people have had trouble finding a resistor that will work.
05-23-2005, 11:04 AM | #10 |
Lovin' Life in Miss.!
Bought mine from partsamerica. http://www.partsamerica.com/ProductD...artnumber=8078
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 05-23-2005 at 11:07 AM. |
05-23-2005, 03:18 PM | #11 |
Blue 67
When I switch to internal regulator alt few months ago, I bought 75 ohm 3 watt resistor from a local electronic shop; 50 cents each, Still working well. I just coverd the resistor in some kind of sheild to protect it from heat and possible trauma. I bought 3 of those. if you like I can look for them. I don't promiss to find them though since my place is a mess right now.
05-23-2005, 08:00 PM | #12 |
You could definately make a nicer harness than that jumper I listed. This was an easy way to go though. Just plug it in.
The truck... you hear that? No really, you did hear that?!!! |
05-23-2005, 10:08 PM | #13 |
Designated A-hole!
Lotsa good info here. See if we can get it to faq.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-24-2005, 09:51 AM | #14 |
