05-21-2005, 10:32 PM | #1 |
Car O'Holic
Hotwireing
Ok so I couldnt get the old key switch out of the old cab but I need to move the truck how can I start the truck with just the black plug that goes into the back of the key switch? What wires do what?
05-21-2005, 11:37 PM | #2 |
The easiest way is run a wire from the positive post of the battery to the positive terminal on the coil (or the batt terminal of HEI). Cross out the switch terminal (the small one closest to the engine) and the battery terminal (the big one) on starter. The engine will run but to cut it off you have to disconnect the wire you hook up from the positive post on battery.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! |
05-21-2005, 11:50 PM | #3 |
its all about the +6 inches
One note, doing it liek that will not let the battery charge.
05-21-2005, 11:53 PM | #4 |
It will work just to move it though. no accesories will work that way. I wouldn't drive it that way.
05-22-2005, 12:23 AM | #5 |
exactly.
05-22-2005, 01:18 AM | #6 |
Got Light Emitting Diode?
if you have a spare ignition cnat you unplug the one and plug in the other? of course thats if you have another
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-22-2005, 11:48 AM | #7 |
You can just unplug the plug from the switch. Then use one wire to jump the power to the run position. and a second to tap the power to the start. They are labeled on the plug but I dont remember which is which. I did this about a month ago to start my parts Blazer and drive it around the yard. Worked very well.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-22-2005, 03:08 PM | #8 | |
Car O'Holic
05-22-2005, 07:05 PM | #9 | |
Msgt USAF Ret
wire labels
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-22-2005, 09:32 PM | #10 |
Unfortunately, you may want to use this thread as a warning to come up with some sort of kill switch, so someone doesn't do this to your vehicle!!
