Livin' it up.
![]() Join Date: Nov 2001
Adjusting doors
Any tips for this i couldnt see what tools would really fit in there to get at it with the door on and the outer fender on too. Any suggestions please?
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Wiseass secured himself a BAN
I have found that ratchet gear wrenches work really well for adjusting the doors. Sears sells them.
Ben |
aka Crusher, Crushergmc
That's what I was going to say, I just couldn't put a name to them.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
There is also a special Boxed in wrench that is shaped like a "S".
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
![]() Join Date: Mar 2002
Sears sells a tool called an Obstruction Wrench that is "C" shaped 9/16 and 5/8 box end. I have used this and it works pretty well. Cost about $16.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
![]() Join Date: Feb 2000
Well NO Doubt about it, it is a Bi#ch to do. But I used a box/open wrench. The S- shaped wrench should work good. I found that if you leave the bolts just loose enough to hit the door with your hand, you can get it where it belongs then tighten it down.
Hope this helps! Good Luck! |
Livin' it up.
Thanks fellas, i'm gonna try it as soon as i get it back from the paint shop...
