Old 05-23-2005, 12:20 PM   #1
Jakes-66-K10
Jakes-66-K10's Avatar
Oil Pressure sensor question
I'm installing my new crate engine and have run into a few problems. One of them is really bothering me - my oil pressure gauge has a metal tube coming from the firewall (with corkscrew things) to what looks like a flare nut thing with threads on it.
Everywhere I look, I keep finding the same sensor that screws into the block and has an electrical connector at the top. I think my oil pressure thing is mechanical not electric right? Kinda new to this...
What do I need, and where can I find this part. I've tried junkyards, vendors, and running out of ideas. Am I the only one with this kind of oil pressure gauge?
Jakes-66-K10 is offline   Reply With Quote
Old 05-23-2005, 12:35 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
You do have a mechanical oil pressure guage. What you will need is something that looks like this. You should be able to find it at a good hardware store or a good auto parts store.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-23-2005, 12:43 PM   #3
Jakes-66-K10
Hmm... that helps but what threads need to be on each end? Is there a board vendor that sells these so I can make sure I get the right on?
Old 05-23-2005, 01:50 PM   #4
arkracing
Weekend Warrior
Probably going to have to buy a kit - usually you can get one @ the parts store with a plastic tube - just use your old copper one. It will come with several fittings for the block/guage and it will come with the ferrules also. usually areound $10 for the kit.
I know for a fact NAPA has them hanging on the rack with thier guages
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 05-23-2005, 01:59 PM   #5
pjmoreland
pjmoreland's Avatar
I lost mine, and I tried finding one of these at hardware and auto parts stores with no luck. The male end that threads into the block is 1/8 NPT and the female end that accepts the fitting on the end of the tube is 1/16 NPT (extremely small and rare). I was lucky and ended up finding mine again.
If you can't find one in a wrecking yard, I'd recommend trying to buy one from www.gmcpauls.com or LMC or somebody like that.
pjmoreland is offline   Reply With Quote
Old 05-23-2005, 02:15 PM   #6
Jakes-66-K10
I've tried both of them and can't find the part. I'll just keep looking, perhaps an Autozone or Checkers or something in another city may have some...
Old 05-23-2005, 04:02 PM   #7
pjmoreland
pjmoreland's Avatar
You might start a thread in the Parts Board to see if anyone has one laying around.
Old 05-23-2005, 04:05 PM   #8
Jakes-66-K10
Thanks, I'll see what I can find but it's a good suggestion. Can I get some kind of conversion to switch this to electrical, seems there is no shortage of those.
Old 05-23-2005, 04:31 PM   #9
pjmoreland
pjmoreland's Avatar
Part number 5182K835 from www.mcmaster.com MIGHT work, but you'd have to cut the fitting off the end of your oil line.
Old 05-23-2005, 08:24 PM   #10
72402
What you need is what da-burb shows a picture of, 1/8 pipe to 1/8 tubing compression fitting. Remove the old nut from your line with a tubing cutter. The original style is almost impossible to find.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 05-23-2005, 11:44 PM   #11
68LSS1
68LSS1's Avatar
http://www.egauges.com/vdo_acce.asp?...Tubing_6&Cart=
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
