Old 05-24-2005, 03:51 AM   #1
jesse977
jesse977's Avatar
Do driprails really prevent leaks???
I have a 74 GMC with no driprails. When it rains water comes in the cab. I thought since my truck doesnt have any driprails that was the cause. My truck is at the shop right now, should I tell the guys at the shop to install them?? Do they really prevent leaks?? If they dont I wont install them since Im not to thrilled about the way they look. What really prevents water from coming in the cab?
jesse977 is offline   Reply With Quote
Old 05-24-2005, 03:53 AM   #2
jesse977
jesse977's Avatar
I know I know its LEAKS not LEAKES, hehehe
Old 05-24-2005, 09:26 AM   #3
Prerunner1982
Prerunner1982's Avatar
they do seem to help prevent water from pooling where the door and cab meet. However, alot of show truck owners prefer to go without and just risk the water, though i cant see many show truck guys driving in the rain to begin with....
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 05-24-2005, 09:27 AM   #4
bodydropped
i have shaved drip rails to and when i open the door water goes in it yes they do stop some of the water from goin in the cab
bodydropped is offline   Reply With Quote
Old 05-24-2005, 09:46 AM   #5
86swb
Born a Chevy Man
86swb's Avatar
Gm put these on their trucks for many years. But now they do not? Go figure.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 05-24-2005, 11:12 AM   #6
Drivin' Miss Daisy
Drivin' Miss Daisy's Avatar
The newer trucks have a channel molded in on the top of the cab that achieves the same thing as the drip rails on the older trucks.
Drivin' Miss Daisy is offline   Reply With Quote
Old 05-24-2005, 02:11 PM   #7
86swb
Born a Chevy Man
86swb's Avatar
So that is what that is for. I never really gave that a thought.
Old 05-24-2005, 01:11 PM   #8
87 Shortwide
Drip rails will prevent some water issues, but if it just straight up leaks, I would be more concerned about your weatherstripping.
Daily Driver: 1992 Blazer dropped on rallys
Project: 87 GMC shortwide, About to get a little boost
87 Shortwide is offline   Reply With Quote
Old 05-24-2005, 01:22 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If water is coming into the truck when it is raining, you need new rubber seals on the door and the cab. Like 87 Shortwide said, if it is leaking, with the door closed you have problems with the seals.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-24-2005, 02:56 PM   #10
whitesswj
Embrace the Redneck
whitesswj's Avatar
speaking of leaks, i've noticed that when i'm driving i just get some drips on my left foot just left of the steering collum under the dash, Where might it be comming from??
sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 05-24-2005, 03:19 PM   #11
Captkaos
Captkaos's Avatar
What truck model are you talking about whitesswj?
On the 73-91's it is usually rust at the windshield drain/lip.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-25-2005, 09:25 AM   #12
whitesswj
Embrace the Redneck
whitesswj's Avatar
sorry, it's a 68
'01 Camaro
Old 05-24-2005, 04:18 PM   #13
Izzy
Trucker.
Izzy's Avatar
I never had an issue when I shaved them on my 83 and drove it in the rain often. I got more wet going to the truck then water dripping from the roof when I opened the door.
Izzy is offline   Reply With Quote
Old 05-24-2005, 04:30 PM   #14
jesse977
jesse977's Avatar
The reason I ask is because my truck is currently at <a href="http://www.serverlogic3.com/lm/rtl3.asp?si=1&k=the%20body%20shop" onmouseover="window.status='the body shop'; return true;" onmouseout="window.status=''; return true;">the body shop</a> and the entire floor is being changed due to water leaking in and causing rust. I will change the rubber seals first, if that doesnt help I'll just bolt on the drip rails later.
Old 05-24-2005, 04:46 PM   #15
Captkaos
Captkaos's Avatar
Not sure what you were trying to link there, but if your entire floor is being replaced you might want to check in the cowl area where the inside/outside firewall meet. You also might want to check in there to see if the factory drain is clogged with leaves/dirt/muck. If it can't drain out to the bottom, it will leak into the floor.
The drip rails not being there aren't going to rot your floorboar out, they are only there to keep run off water from dripping on your head when you get out of the truck. My '73 pickup doesn't have them from the factory (73 didn't have them, and '74 they were optional) and my floorboard is ok. Putting driprails on there won't solve the problem.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-24-2005, 04:58 PM   #16
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Drip rails
With these year model trucks one other problem can occur and cause the leaking you are taking about. I know when I got my truck painted and had different doors installed with new weatherstripping mine leaked. The body shop gently bent the top part of the door in towards the cab for a tighter seal. They did this by grabbing the top of the door and placing a foot at the top of the door panel and pulling in, not what most people want to do to thier doors but it did work, no more water and a lot less wind noise. Might want to have the body shop give it a try.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 05-25-2005, 08:46 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by TexasJeff
.... The body shop gently bent the top part of the door in towards the cab for a tighter seal. They did this by grabbing the top of the door and placing a foot at the top of the door panel and pulling in,......
That's not uncommon on these trucks. I have never seen anyone use their foot, but I have seen it done with a 2x4.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
