A fellow board member was kind enough to hook me up with the parts to convert my sisters 69 3/4 ton GMC to PS. I was wondering if anyone had some pics to post or send of there PS installed. I am still unwise in the ways of GM wrenching, I have always had fords. I'm not biased by any means, just always seem to end up with them. (Please don't hate me.) I really like this GMC, I take care of it for my sister, she only has room for 2 of 3 cars at her place, so I keep it at my house and get to drive it occasionally to maintain it.
If at first you don't succed, break something! ![]() |
Here are a couple of pictures of the steering box and hoses. It is pretty hard to show the pump as it is pretty low on the engine.
Jim |
Thanks, it does sit pretty low, I scraped off the gunk and found the 2 mounting holes. I have the pump mounted on the block now, but the pulley on the pump sits too far back to line up with the crank pulley. Is it okay to use a pulley puller and move the pulley forward a little bit? it's only off by about 1/2 the width of the pulley.
P.S. Hey Teeitup, thanks for sending that extra balancer bolt, mine turned to crap when I reinstalled it after swapping pulleys, totally trashed the threads, I was able to clean the hole and use the bolt you gave me.
Do you have a cast crank pulley on the engine? It sounds like the pump and crank pulley may be different years.
Pulling the pulley forward is not a good idea. You may be able to fix the problem if you can locate a pump pulley with a different offset as there are different pulleys. Jim |
The crank pulley is a 2 piece setup, a flat pulley for the alt. belt, and the other pulley bolts to the front of the first one, but sticks out a little further.
What year set up is that for? The setup I have on my 70, came off a 71 PS truck and the hoses are ran differant. Are all 67 to 72 PS hoses run the same way?
1997 GMC Sierra Ext 1965 Mustang |
