Old 05-29-2005, 11:41 AM   #1
modifiedGMC
pan hard bar question about lowering truck
Does the panhard bar have to be made adjustable when you drop the rear? I was using a cable hoist ran under the rear end and connected to the frame above it to pull the truck down to get an idea of the drop I want. It would only go about 2" and stopped but the snubbers were NOT bottomed out, so I figured the panhard bar was stopping it. any ideas?
Could the rear coils be cut and then bend the end back into the curl for mounting?
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 05-29-2005, 01:37 PM   #2
XXL
Seņor Member
XXL's Avatar
No. Adjustable just lets you "tune" the length. Once you adjust it, you never need to again.
XXL is offline   Reply With Quote
Old 05-29-2005, 02:38 PM   #3
neonlarry
neonlarry's Avatar
^But as you lower the rear it shifts to one side, thats why they made the adjustable bars so you can recenter your rear. With 2-3" you can probably get by without an adjustable bar but any more than that and you start affecting tracking and u-joint and carrier bearing wear.
On the springs how would you recurl them? if you heat them they are DOA.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-29-2005, 04:33 PM   #4
XXL
Seņor Member
XXL's Avatar
As I said, once you are recentered, you don't need it to adjust any more. "Adjustable" sounds as if it indicates some kind of ongoing thing. It's not.
Old 06-01-2005, 06:00 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
Im running a stock bar on a 5" rear coil drop and it seems fine, course it might look different if I was looking at it going down the road.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-01-2005, 07:37 PM   #6
neonlarry
neonlarry's Avatar
Easy way to check measure opposite frame rail to backing plate flange for both side and see if they are the same.
Old 06-02-2005, 05:37 AM   #7
modifiedGMC
Maybe I should have not used the word "adjustable", I should have said does it have to be shortened? See the problem I'm having is when I started to drop the truck down it stopped before it got to the point I wanted. I didn't know if the panhard bar was stopping it or the drive shaft not letting it go down, but something stopped it from going down. Like I said before the rubber stoppers on the rearend still had space between them and the frame and I didn't see anything but the panhard bar and/or drive shaft that could be stopping it.
Old 06-02-2005, 08:23 AM   #8
smokekiki
Mike
smokekiki's Avatar
Your springs are pretty stiff.I think that is the problem You are having.The panhard keeps the rear centered.The only way it would limit the suspension is if the wheel and tire are pressing against the body!
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
