05-30-2005, 09:52 PM | #1 |
Embrace the Redneck
wtb: 5 speed for pu.
With gas the prices being 2 bucks a gal and me only getting 10 or less MPG from my 3 speed and the 3.73 rear, i want a 5 speed because i like the 3.73 rear.
i figure if i can get a good 5 speed for a decent price i can cut back on MPG. Anyone in the MO IL AND IA tristate area have a good deal for me then send me a msg or pm. my set up now: 68 c10 350 bored .060 edle 1405 carb edle preform intake KN airfilter headers 3 spd. 3.73 rear. please help w/ 5 speed. sswj
'01 Camaro Son, you just can't get there from here... |
05-31-2005, 02:01 PM | #2 |
Embrace the Redneck
ttt
06-02-2005, 02:03 PM | #3 |
Embrace the Redneck
anyone???????????
huh huh??
06-03-2005, 07:23 AM | #4 |
I`d try this in the post-88 section,since they had 5 speeds.
06-03-2005, 07:40 AM | #5 |
The late model truck 5 speeds work nice but most require electrical operated speedo's. I ran one for 5 years (96 truck 5 spd) with no problems but the speedo thing is a PITA. If you plan on running the truck--racing etc.--you are going to have to spend some $$ to get a 5 speed that will hold up. I spent $1,000. for my setup with hydralic clutch, reworked drive shaft, reworked clutch linkage, etc. You may not see the gas savings soon enough as you will get a few more MPG but---do the math. Unless you really drive the heck out of the truck, it will take years to recover and come out ahead. Might be better off hooking up a gear vender overdrive behind your existing trans or go with a original truck 4 speed. You will have an 8 speed capability! This way you can pull the add-on overdrive when you sell the truck and move it to the next one. Often see these OD on e-bay for around $1,000-1,200. used and guaranteed. Good luck
06-05-2005, 08:55 PM | #6 |
i bought a 90 chevy truck 5 speed tranny (nv3500) with the driveshaft and all of the hydraylic clutch parts for $180 bucks of craigslist. i haven't installed mine yet, but i know it does have an electric speedo sender. i'm starting to see a lot of 88 and newer trucks in junkyards, a couple of them had the 5 speeds. if you have an engine with a lot of torque you might want to find a nv4500, it's a heavier duty tranny. i just saw in my truckn mag that gm came out with 6 speed turbo hydromatic. i bet that will cost you, though. there's deals out there, good luck!
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
06-06-2005, 10:07 AM | #7 |
Embrace the Redneck
What i'm needing is just an overdrive Tranny. something that has a less that 1:1 "Last" gear. If the 4 speeds from our years are such as the one in question then hey i'm all over that one. but are they?
06-07-2005, 07:36 AM | #8 |
In the early 80s there were 3 speed + o/d 4 speeds.The NVs should be abundant and cheapest way to go.GearVendors is the hot set-up,$2500+/-new and driveshaft costs.The only swap that won`t require d-shaft work is a 4 speed car trans,but no o/d.The first trans I mentioned,if you locate one,would be straight forward and cheap.May not need d-shaft work.There`s always the 700R4 route.
06-07-2005, 11:11 AM | #9 |
I used a manual trans from an '81 chevy half ton, 3 speed plus overdrive, Almost direct bolt in except for the shifter, overall length same as 3 spped manual and the turbo 350. Fits standard bellhousing too. It is a gm bolt pattern ,chrysler/new process or is it new venture now ? A833 style trans. Pefect for me, little hard to find though. I did a lenghty post/ reply session on the forum board last fall detailing all, too bad search is down.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
06-07-2005, 11:18 AM | #10 |
