Old 05-31-2005, 02:10 AM   #1
Slammed66
Needs a Big Block
Slammed66's Avatar
How do I "roughly" set an allignment?
such as the title states I need to set my allignment roughly, good enough to drive the truck to the allignment shop, who what where why? Id appreciate it
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 05-31-2005, 08:40 AM   #2
XXL
Seņor Member
XXL's Avatar
Stick align. Use a tape measure from tire to tire. Make the front and rear distance the same mius 1/2" overall (that's about 1 degree of toe-in). Make sure you center your steering wheel midway between locks before you adjust. For camber, if you're going straight to the alignment shop, just make them 'look' level. It's easier than actually trying to dial it in without gauges. Caster is partly a product of the camber adjustments. If you don't have anything bent, just keep your camber shims the same on the front and rear studs and you'll be plenty close.
XXL is offline   Reply With Quote
Old 05-31-2005, 02:19 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Set your camber first, then adjust the toe. Any in/out movement of the upper a-arm will affect your toe adjustment.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 05-31-2005, 09:49 PM   #4
Slammed66
Needs a Big Block
Slammed66's Avatar
thanks guys
I should be rollin soon
1964 Short box
1972 K10
Old 06-01-2005, 09:05 PM   #5
Elsie72
Chinook Arch
Elsie72's Avatar
I wouldn't worry about anything but the toe setting if you're just driving to the alignment shop. Caster is not a tire wearing adjustment, and toe is very easy to set. A bit more camber than spec will not destroy tires in 100kms, and kind of looks cool, imo.
Just make sure your shop of choice has experience with aligning dropped trucks, or get them to estimate before starting the job, or you may be surprised with the bill you get.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
