It's Done When It Runs!!
Gear Drive ?'s
For those of you running gear drives, can you use the stock cover for the gears with dual idlers? They look like they might me too wide for the cover. Pics would help also if possible.
Thanks for the help.
I have a cheap proform chrome cover and it clears but you need to run a cam button to keep the cam from walking. I have video but I can't figure out how to put it on here.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#3 | |
~Rest In Peace~
nice truck but i bet stop sucks
![]() also i would get some heat socks for the wire set keep them from burning on the headers just my .2 worth
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Yes they are usually designed to fit under the stock cover. I had to grind my block a little for the idler gears to fit inline with the cam and crank gears. I was running a Pete Jackson. Almost everyone I know who ran the Pete Jackson had to grind their block alittle bit. I`m nor sure about the other brands.
Anthony |
