Horn relay?
My '77 has an underdash plug-inrelay for the horn, which works. It also has a horn relay mounted on the radiator support that doesn't work. It's rectangle, flat on the side that mounts against the support, and rounded on the other. It has 4 connections that use a screw to hold down the u-shaped wire ends. One is for ground, another gets 12V when you push the horn button. The other two go to each horn. I can't get a part number for that relay. Anyone know which one it is?
Real Name - Brandon Current Vehicles: 1977 C20 Silverado 454/TH400 3.73s 1989 Jaguar XJ6 in the middle of an LT1/4L60E swap |
Anyone?
Do you have any pictures of it? I personally have not seen one like you are describing.
One ground and a 12 voly source only when the horn button is pressed? Assumed to come from the relay under the dash? And the other two go to the two horns. Does not sound like a relay to me. A relay would have a constant 12 volt supply also. Could be some type of 'free wheel' diode assembly to keep the 'back EMF' out of the electrical system of the truck. Are these some type of after-market horns? Last edited by NeCrOmAnCeR; 06-03-2005 at 09:05 AM. |
#4 | |
Sounds right. The under dash relay is the only one on my truck. I will have to try and find one to see I guess. Good luck!
