06-02-2005, 02:00 PM | #1 |
GMC 305 V6, anyone out there?
I haven't seen much reference to this uniquely GMC engine on this forum. Do any of you guys drive one of these? Mine is a 65 with the four speed. I just got it and want to start gathering information about these things. I've been to the 6066 site, which is a nice source. Anyone into these? Brad
06-02-2005, 05:40 PM | #2 |
Registered Smarta$$
i got one in my 63 w/ the 4spd.
63 GMC custom going to be slammed |
06-02-2005, 11:22 PM | #3 |
I've got 4 trucks with V-6s, they're something just a little different!
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
06-03-2005, 03:00 AM | #4 |
I must have rocks in my head, but I'm on my second 3/4 ton GMC w/305 V-6 & 4-spd.
Owned a '65 for eight years and have been kicking myself ever since the day I sold it. Just bought a '67 in March of this year and I'm starting to tinker with it. In a nutshell, I think these were some of the coolest TRUCKS ever built. The amount of low-end snort these engines produce is practically beyond description. Brad, welcome to the brotherhood. rwgregory
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
06-04-2005, 04:03 AM | #5 |
I heard it said the V-6 wasn't too good for mileage,but I borrowed a friends '64 with a 305 V-6 in it to go about 250 miles away to get an engine,and at 70 mph,it averaged 18 mpg.That ain't bad,especially after me getting about 6.5 pulling my trailer down from Idaho in my '57 GMC with a 347 V-8,at 40 mph. (scarey handling and 3 dead cylinders.) BTW-check your rear end ratio-a lot of V-6 trucks had 3.08 Post rear ends in 'em.
-57 GMC 1/2 ton longbed,Pont. 400,4 speed -62 Chevy 1 ton duallie,Chevy 355,4 speed -66 Pontiac Catalina 2 dr. hardtop,389,T-400 -81 Ford Fairmont wgn.,2.3,4 speed -68 Triumph TR6-R 'cycle,various mods -66 C-60's back -there's probably others... |
06-06-2005, 03:41 PM | #6 |
Diff gears in my 65.
The part about checking the rear gears is interesting. I was told it had a posi, but how do I know the ratio without pulling the cover off? Do they tag those rear ends outside the case? It's still sitting in the tall grass, awating an open bay in my barn. Is the 307 posi a "sought-after" item? Brad
PS it would be cool to have a unique thread for the 60-66 V6'ers. Probably not that many around. Has anyone ever converted one to 4x4? Brad Last edited by hannamet; 06-06-2005 at 03:44 PM. Reason: Just to add stuff w/o making thread longer. |
06-06-2005, 09:03 PM | #7 |
Brad,
4x4s were available with the V6 in all years that the engine was offered in light trucks. It was also available in the KV4000 4x4 and in NAPCO conversions to 4x4 or even 6x6 in the larger trucks. Bob
06-07-2005, 03:04 AM | #8 |
Brad,
Your truck should have a Dana rear-end under it. Dana-60 for 3/4 ton & Dana-44 for 1/2 tons. All Dana rears came with gear tags attached to the bolts holding the rear-end covers on. Now you just gotta hope that in the last 40 years nobody has removed the cover and forgot to replace the gear tag upon reinstallation. rwgregory
06-07-2005, 12:39 PM | #9 |
rear end
Thanks RW, now I'm gonna go home and crawl under the truck and see if a tag is there. Do you know what "code" would indicate a posi? Thanks for the info. Brad
06-08-2005, 03:33 AM | #10 |
Brad,
If your truck is a limited slip, there would be two tags bolted to the rear-end cover. One would be the gear tag,normally toward the bottom of the cover, and the other one would say:"USE LIMITED SLIP GEAR LUBE ONLY". That one is normally at about 3:00 clock in the area of the fill plug. Of course that's hoping nobody has removed the tags over the past 40 years! Then again you could always jack up one rear wheel and see if it spins with the trans in neutral and the E-brake off... Good luck, rwgregory
06-10-2005, 12:18 PM | #11 |
Dana diff
Hey guys, I crawled under that thing and a tag existed on the drivers side about 9 o'clock. It's a bit redundant: it says 3.54 at the bottom of the tag and "46-13" at the top. Duh! Can't most folks divide 46 by 13? I thought it was kinda silly. However, no tag at 3 o'clock that I can see. Guess I'll have to wait a bit since it would'nt be fun pulling it apart where it's sitting right now. The driveline is off or I'd try the jack and spin thing. I'm glad it's got the 3.54 gears, it should do a bit better as a daily driver that I don't intend to do any heavy towing with. The driveline needs new U-joints; something I CAN do without moving the truck. Thanks for your comments. I'm really looking forward to getting this truck running so I can really check it out. Brad
06-12-2005, 01:53 AM | #12 |
Brad,
Now this is a longshot, but hear me out. Wouldn't a missing driveline do the same thing as putting the tranny in neutral?? Just a crazy thought... I amaze myself at times..... rwgregory
06-15-2005, 01:04 PM | #13 |
Uh, DUH! I'm probably the kinda guy that should'nt be under there in the first place. At any rate, the second "tag' isn't there, so I'm pretty sure it isn't a posi. I will eventually take the cover off and look, when I get it inside. Any ideas about an aftermarket air filter? The OEM is missing, and I was wondering what others do with the stock V6 carb? I'd like to start by making this a short trip daily driver for my daughter, leaving everything stock and SLOW........ Thanks, Brad
06-15-2005, 01:13 PM | #14 |
Brad,
I've rebuilt one of the carbs and replaced another one with a Holley 500 cfm 2 barrel because the throttle plate was cracked. The Holley definitely runs better than the Stromberg. You can find more information on the swap on Jolly's site. http://www.6066gmcguy.org/holley.htm Bob
06-16-2005, 03:36 AM | #15 |
Brad,
Hope you don't mind me getting a chuckle at your expense, but I just couldn't resist. As for an air cleaner, practically any aftermarket 1 or 2 bbl. air cleaner with the right size hole should work. Just check out your local discount auto parts store & see what they have. I'm in the midst of collecting the parts to do the 500 Holley carb swap on my '67 so I will have a stock air cleaner available sometime in the not too distant future. If you still need one somewhere down the road, maybe we could do some "bidness". Good luck with your project. rwgregory
06-17-2005, 12:16 PM | #16 |
@ bbl carb
Are you guys going with a "new" carby, or are they readily salvaged off of a common vehicle? Not sure what I should look for. Sounds like the answer to me versus trying to make the single work. I'll read Jolly's stuff again, its been awhile. You can laugh at me anytime, I try to laugh at myself, but I don't always "get it?".
06-17-2005, 11:15 PM | #17 |
I went with new to eliminate some of the hassle of chasing down problems with a used carb. I bolted it on and it ran great.
Bob
06-18-2005, 03:13 AM | #18 |
Brad,
I'm also going with new parts only because there are many self proclaimed carburator "experts" out there that can royally screw-up a perfectly good mixer. Personally, I would only buy a used carb from someone I knew. FYI, I'm figuring a total cost of about $300/325.00 for the complete changeover,(carb,adapter plate,air cleaner, plumbing,fuel filter & misc. hardware). I've read good things about this swap, and am eager to get mine done. Best of luck if you choose to go this route. rwgregory
06-21-2005, 03:52 PM | #19 |
Carb switch
I'm gonna go new as well. On another topic, is there something unique about the V6 starter or is it basically a chevy starter? Mine is AWOL, and I've gotta hunt one up. I haven't tried a Chevy starter yet, but I will if it will bolt on. Shimming or other issues regarding GMC startes I should know about? (My service manual hasn't shown up yet!). Thanks, Brad
06-22-2005, 03:30 AM | #20 |
Brad,
The only time I ever dealt with a V-6 starter was when the starter on my '65 grenaded on me. I had a local auto-electric shop in San Diego rebuild it for me at a fraction of the cost af a new one. This was back in the late '80's and if memory serves me well, the V-6 starter was unique. However, they were redally available but they weren't cheap! As far as shimming, it wasn't necessary. It just bolted right on. To buy one outright, you may want to try NAPA. They still list lots of parts for 305's. rwgregory
06-23-2005, 10:59 AM | #21 |
Starter for V6
I was looking for the starter on Rock Auto and when I compared part numbers for a 1965 GMC V6 starter to a 1973 Chevy 350 V8 starter, they appeared to be one and the same. We'll see. I've got the Chevy starter in hand, so that would be a savings. Once I finish dismantling the 73, I should be ready to start putting the 65 together. Oh I love summer time! Brad
06-28-2005, 09:09 PM | #22 |
I think the starters are different, not sure though. I'll be back home this weekend and will compare the two, side by side.
Bob
07-05-2005, 10:54 AM | #23 |
The motors could be the same and I think a lot of the parts for rebuilding one will be the same but the noses where they bolt up are very different. The GMC is a lot beefier.
Bob
07-06-2005, 12:47 PM | #24 |
Thanks Bob, guess I'm in the market for a starter, or at least a rebuildable core. Anyone have one? thanks, Brad
07-08-2005, 04:41 PM | #25 |
BobS, I am just picking up a '67 with a 351E V6. Sounds like you're the guy to ask for V6 questions. Just curious about part interchangability between the 305 vs 351. Is it the same block with a different crank/piston size?
