Old 06-03-2005, 12:53 AM   #1
skokie
skokie's Avatar
Intake Manifold question
Ok here is a dumb one. What are the center ports on a intake manifold for? Reason I ask is because I am going to be taking off my 2101 to get it cleaned and the new gaskets I bought (fel pro 1205) has no hole in the center.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-03-2005, 12:57 AM   #2
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Pictures?
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 06-03-2005, 12:59 AM   #3
kwmech
Heat crossover?
Old 06-03-2005, 01:32 AM   #4
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Sounds like the heat riser. If you're still running the factory heads and intake you'll probably want different gaskets so it will work properly.
On the other hand I did the same thing you're contemplating and ran the gaskets without the heatriser openings when I replaced my old intake with an Edlebrock Performer.
When I took it off to do my engine rebuild I discovered that the heat had blown a hole through it anyway so I had the heat riser operational even though I had intended to block it off.
So maybe it really doesn't matter if you get different gaskets. The exhaust heat may burn a hole through them anyway.
Old Yeller 1970 is offline   Reply With Quote
Old 06-03-2005, 02:07 AM   #5
pjmoreland
pjmoreland's Avatar
If you have a heat-activated choke (bimetallic coil), the heat passing through the center ports on the manifold will help open up the choke.
pjmoreland is offline   Reply With Quote
Old 06-03-2005, 02:13 AM   #6
skokie
skokie's Avatar
Here is the pic of the intake with the port circled in red. If those ports are the exhaust ports then the gaskets look to be the wrong ones. Or are they supposed to be blocked off? Engine is a 350 target master crate.
68 build thread
Old 06-03-2005, 02:23 AM   #7
pjmoreland
pjmoreland's Avatar
That's the heat riser port.
Old 06-03-2005, 03:01 AM   #8
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
me myself and irene would use hi temp rvt
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-03-2005, 11:30 AM   #9
skokie
skokie's Avatar
HMM i cant remember if the gaskets I put on there had a center hole or not.
68 build thread
Old 06-03-2005, 12:03 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Being that you are in So Cal,Brad, you won't need the heat riser and it would help to
prevent carb overheat and boil over. Just my .02
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-03-2005, 02:39 PM   #11
68Stepbed
68Stepbed's Avatar
I use a Fel-Pro 1204. It has a metal block off plate. The 1205 just has regular gasket material and will burn through.
I agree with VetteVet about your SoCal location. It just depends what carb you are running. If you have a hot air choke you need a gasket with the hole in it. If an electric choke I would use the 1204.
Gas burns better when it's cooler. Blocking off the heat riser will improve throttle response unless it's really cold. Cooler temps will cause the fuel to wash the cylinder walls because a cold engine can't burn cold gas fast enough.
Good luck. Hope this helps.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-03-2005, 02:57 PM   #12
skokie
skokie's Avatar
I called edelbrock and they said the correct part is a 1256. Also I am not in so cal. I am in no cal but it does get kinda warm up here
68 build thread
Old 06-03-2005, 05:57 PM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Sorry Brad
Sorry Brad, I should have checked. When you live in Mich anywhere in Cal. is warm. LOL
VetteVet
