Old 06-06-2005, 09:01 PM   #1
ocbaud
Garage Queen Material
bent a pushrod
yeah, i'm still here for a little while longer
wont know about the jetta till about thursday.
anways, my rocker arms have been becoming loose after only hours of driving the truck after adjusting them. i've adjusted them 4 times in the past 3 days and the same ones keep getting loose. well, this happened today:
yes, those are hardened pushrods....
so, what would cause this to happen? i didnt have them over adjusted, and when i pulled the valve covers the past couple days, there were 2 rockers loose and were makign loud loud noises. so today i had to fix it after driving for 10 minutes and finally made it halfway home before it started again, got home, let it cool, checked it out and thats what i found.
no place is open right now that sells hardended pushrods either
ocbaud is offline   Reply With Quote
Old 06-06-2005, 11:52 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You have a serious mechnical problem. You need to go through the valve train before you destroy engine parts!!! Especially pistons and valves.
Man you seem to have some serious problems with your truck. I should take off your hands to drive it like I drive mine.
Old 06-07-2005, 06:21 AM   #3
Trimman
Trimman's Avatar
what ratio rockers are you useing?
82 C-10 Scottsdale LB owned since 89
350 crate vortec heads Crane 1.6 full rollers
edelbrock 1406
edelbrock performer eps intake
dynomax headers/flowmaster 70's
BTO 700r4 level 3
custom 2 piece driveshaft
12 bolt gov loc w/3.08
Trimman is offline   Reply With Quote
Old 06-07-2005, 07:31 AM   #4
Nolowrider
Nolowrider's Avatar
The only thing I can really think of that would cause the rocker to back off is, a bad stud or maybe the nut. Is you studs threaded in or pressed in? Maybe get a cheap rod and new nut and try it.
Nolowrider is offline   Reply With Quote
Old 06-07-2005, 09:04 AM   #5
86 GMG
do you think that your timing chain has jumped a tooth? taht could cause this i think
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 06-07-2005, 09:09 AM   #6
Nolowrider
Nolowrider's Avatar
Yea, a jumped timming chain would do that, but it would usally be more than one rod bent. Plus, he said he had trouble with the rockers backing off.
Old 06-07-2005, 09:16 AM   #7
hotrodhomi
hotrodhomi's Avatar
What if one of the lifters were stuck. I would try to grab that sucker with a magnet and see if it moves freely.
hotrodhomi is offline   Reply With Quote
Old 06-07-2005, 09:57 AM   #8
Moostifer
a fool with no money
Moostifer's Avatar
had the same problem a few years back on a fresh rebuild... at first I thought it was the nut backing off, so I put Locktite on it and marked the nut & stud with a paint marker so I could tell if it was backing off. Two days later, it was tapping again and the nut hadn't moved. I was like "W.T.F. ? so I pulled the intake and checked the lifter, it was fine, so now what?.... long story,short, the pressed in stud was slowly pulling out, I put a screw-in stud in and never had another problem.
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 06-07-2005, 10:30 AM   #9
ocbaud
yeah, these are already nice screw in studs. but they are harland sharp roller rockers, which i've heard some complaints about this brand coming loose.
how would i know if it jumped a tooth? when i was adjusting the other ones, it looked like the balancer was about 5 degrees off from where it used to be at tdc(my balancer is degreed)
Old 06-07-2005, 10:59 AM   #10
Moostifer
Moostifer's Avatar
only way to tell for sure... take the timing cover off, pull the plugs, and crank the motor over by hand and make sure your timing marks line up.
a weak valve spring might cause this problem...
Old 06-07-2005, 11:10 AM   #11
Nolowrider
Nolowrider's Avatar
Maybe it did jump a tooth. Sort of sounds like it now. Like Moostifer said, yank the timming cover off and take a look. Kind of a PITA though to get to it just to take a look. But, might as well replace the set while you are in there.
Old 06-07-2005, 06:50 PM   #12
jermasaurus
jermasaurus's Avatar
I know whats wrong..... The truck doesn't want to be sold.
jermasaurus is offline   Reply With Quote
Old 06-07-2005, 08:39 PM   #13
ocbaud
FU CK!
i cant get the lifter out to check it with out taking the intake off damnit i have to much work to do to this truck. plus i have class tommrow and aevery damn day. god i cant wait to get this thing off my hands.
and yes, the truck is pissed off cause i'm getting rid of it.
Old 06-08-2005, 09:01 PM   #14
Tom
driving is in my blood
Tom's Avatar
The truck dosen't care your getting rid of it, its the fact your getting a VW that pisses it off. At least your not getting a mitsubishi.
I would say either the rocker arm nuts or else the cam/lifter is the culprit. Either way the truck is not operable right now and needs to be parked.
Old 06-08-2005, 09:14 PM   #15
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Hell him getting a VW pisses me off!! Traitor!!! Thats a womens car right?? JK!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 06-09-2005, 09:16 AM   #16
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
This may be a little off-topic, but did you find out what was causing the knocking noise a few weeks ago? May have floated a valve and bent it, causing the piston to hit the valve while held open by the cam, thus causing the bent pushrod. (.490 lift is border line for needing to check piston to valve clearance)
As far as the rockers backing off, is a common complaint it seems with the Harland-Sharp rockers. As for yours needing constant adjustment the last few days, I'd say that the push rod bend was getting worse, every time you adjusted it would bend a little more.
Hardened pushrods do not prevent bending, only prevent the rod from galling (SP) on the guide plate. Checking for pulled/streched rocker studs is as easy as placing a straight edge on top of the studs (front to back) all the studs should be at the same height, a longer one needs to be checked out.
You also need to check the rocker arm geometry real close before buttoning it back together.
NeCrOmAnCeR is offline   Reply With Quote
Old 06-09-2005, 11:06 AM   #17
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
are you using poly locks on the roller rocker arms ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-09-2005, 04:05 PM   #18
Moostifer
Moostifer's Avatar
have you concidered that a lobe on the cam may have gone flat? that would explain having to adjust your rocker... and the bent pushrod.
