Old 06-06-2005, 10:27 PM   #1
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Washed off the dust today.
Finally got the pics on here. I pulled the frame out and washed off the winter dust & cobwebs. Will prolly set the cab on next week. Can't wait to get started again!
Botietruck is offline   Reply With Quote
Old 06-06-2005, 10:46 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
clean inline you got there
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 06-06-2005, 10:57 PM   #3
Geezer
Geezer's Avatar
Looks great! And A/C Too! Say, you mind telling me how you removed the cab without hurting it?
Geezer is offline   Reply With Quote
Old 06-08-2005, 10:00 PM   #4
Botietruck
Botietruck's Avatar
cab removal.
I've had that cab on and off several times. With the doors off and the cab stripped, it takes 3-4 good strong bodies to get it on and off without straining. We pick up at the bottom of the rockers and once it's off one on each side and one at the front & rear. Two can do it, but I don't recommend it.
Bob
Old 06-07-2005, 09:44 AM   #5
Yukon Jack
Yukon Jack's Avatar
Looks great. Lots of cleaing time went into that frame.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-07-2005, 09:51 AM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Thumbs up
Not may have the foresight to buck the V8/Auto trend and keep the in-line and 3 speed column shift tranny. Good for you. It'll pay dividends in the long run with ease-of-maintenance and trouble-free simplicity.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-07-2005, 11:17 PM   #7
SCOTI
SCOTI's Avatar
Ease of maintenance & trouble free simplicity my arse. While I loved my 6cyl/3spd & I'm a huge column shift fanatic, the column shifter linkage & that trans leave much to be desired. How does one fix that? Swap in another 3spd column & then another trans.
A few months later.... that 'new' shift linkage keeps hanging up in gear (so much that it killed the clutch). You're finally fed up enough to cut a hole in the floor of your cab & stick in a floor shifter . . ..... only then to have the tranny start crapping out on you!
The simple, low maint fix?
Swap a tried & true sbc w/a turbo 350 trans.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-08-2005, 06:51 AM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
I used to have the "lock up" problem too until an old guy showed me how to shift it properly. If you use a slow deliberate motion without ramming and jamming, that old linkage will give you years of trouble free operation. It's when you force things or try and "speed shift" that you run into problems. Like a lot of things, there is a right way and wrong way to do things. This system has outlived its usefulness in todays society due to driving conditions and a lack of patience in general. However, if maintained and used as intended, it is a simple and trouble free setup. I suspect the majority of problems with this setup can be directly attributed to the impatient and untrained "nut" behind the wheel.
Old 06-08-2005, 09:38 AM   #9
SCOTI
SCOTI's Avatar
And I mean this in the nicest way. Your not the only one that's been around these trucks for any length of time. I don't 'speed shift'. I use(d) slow, deliberate movements from gear to gear. As you stated, if you force the shift, it will most likely hang up.
I'm also not an impatient nut (not that you were calling me one). I've set up several of these column shift trucks that worked . . ..... for a while. Then the problems would start again requiring more adjustments. So I feel confident I can set one of these up adequately. I even ask questions in order to learn more & help identify some things I possibly missed.
You may love the 3spd columns as much or more than me, but for the average joe, the column shift auto has fewer issues w/day to day reliability . . ..... abused or not.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-07-2005, 10:53 AM   #10
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Looks nice. I wish I had that patience.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 06-07-2005, 11:22 AM   #11
farside847
farside847's Avatar
Looks like all you need is a bucket seat bolted down and your off!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 06-07-2005, 12:03 PM   #12
67chevemall
67chevemall's Avatar
take lots of pics of the cab install! That sure looks good!
67chevemall is offline   Reply With Quote
Old 06-07-2005, 02:50 PM   #13
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Very nice looking frame.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 06-07-2005, 02:58 PM   #14
67ChevyRedneck
67ChevyRedneck's Avatar
Very very nice!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-07-2005, 06:44 PM   #15
Gee_Emm
Nice!
I am adding AC and PS to my 292, can you post some close up pictures of your pulleys and belt routing? I am having a hard time figuring out how it is supposed to be setup.
Gee_Emm is offline   Reply With Quote
Old 06-07-2005, 09:24 PM   #16
Looks like an assembly-line picture,except for the grass.
Old 06-08-2005, 10:18 PM   #17
Botietruck
Botietruck's Avatar
Some have asked about the a/c pics.
Old 06-08-2005, 10:31 PM   #18
Gee_Emm
Thanks for the pictures, they are invaluable to me at this point.
What is the AC compressor bracket from?
Is your altenator pulley 1 or 2 groove, I have a 3 groove balancer but I probably am going to have a hard time finding a 3 groove water pump pulley no that it looks like I need one.
Old 06-12-2005, 10:20 PM   #19
Botietruck
Botietruck's Avatar
Arrow More cab install pics
Well, I finally got the cab on the frame Saturday. Had to do it with two (my son and I)... wasn't too bad. In response to CPNE, I plan on going back with as close to original as possible, except for the a/c, p/s & p/b. I will go back with the column shift.
For GeeEmm, the compressor brackets are from a late "70's van...I believe. Everything bolted up ok, just had modify that long support bracket from the compressor down to the front corner of the block. Pulleys are from the same.
The project has come to a stop over the past several months but this board has reignited the spark to get my butt in gear and start back on it. I enjoy surfing the site every day.
Old 06-12-2005, 10:27 PM   #20
Gee_Emm
Looks good. Do you know about the special air cleaner needed for 6's with PB?
Old 06-12-2005, 10:29 PM   #21
Botietruck
Botietruck's Avatar
No! Do you know something that I don't know? What's the scoop?
Old 06-12-2005, 10:38 PM   #22
Gee_Emm
It is called an overslung air cleaner. Its like this to clear the brake booster. I figure I had better mention just in case you need to start looking for one. They aren't all that common and if you do find one it could be $$$$
Old 06-12-2005, 10:37 PM   #23
HOTFUN
HOTFUN's Avatar
I just love original ginny trucks. Very very nice work.
Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 06-13-2005, 06:13 AM   #24
Botietruck
Botietruck's Avatar
Thanks for the info. I'll start looking.
Bob
