Old 06-08-2005, 05:25 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question Hey Guys, Got A Question
How do you adjust the detent cable, when I looked at mine it looks
like the carb throttle thingamadohitchy has to move around 3/4 of
a inch before making contact with the end of the eyelet, I drove it
about 18 miles to day and everytime I stomped it it wouldn't drop
down a gear, it just kinda slowly accelerated, should the eyelet be
against the pin in the park, engine off position, pic to follow soon.
*Sorry for the crumy pic's, it's in one of the ba$tard spots to get to
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-08-2005, 06:10 PM   #2
vtblazer
vtblazer's Avatar
That's your tranny kick down cable.
When you get on the throttle it should drop a gear for better acceleration.
Shouldn't have anything to do with the gear you start out in.
Unless of course it's messed up or adjusted wrong...
vtblazer is offline   Reply With Quote
Old 06-08-2005, 06:28 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
That's what I'm asking, should it look like that in park, w/ the engine off,
or should the eyelet be all the way to the left? (No gap in there like now)
Old 06-08-2005, 07:28 PM   #4
k5keith
it's been a while but i think it should just make contact when the secondaries start to open. Im could be all wet. But hey i live in oregon i'm used to it.
k5keith is offline   Reply With Quote
Old 06-08-2005, 07:42 PM   #5
Nolowrider
Nolowrider's Avatar
Usally to adjust it takes a little tinkering with to get it to kick down when you want it to. There should be a bracket on the back of the intake manifold where the detent cable goes through. The part on the cable that you are looking for should be square where it goes through the bracket. If you look at it you will see where you can pull on side of it up, kind of like "unlocking" it. That is where you adjust it. With the engine off, you have to open and close the throttle a few times to get the end of the detent cable to make contact with the carb linkage pretty much when the carb is wide open. Like I said, you may have to play with it, you may want it to kick down a little before wide open, depends on how you drive. Adjust it, then drive it and see how it works for you.
Nolowrider is offline   Reply With Quote
Old 06-08-2005, 08:23 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
just like he said above but when adjust full throttle then close the detent thats the adjustment
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-08-2005, 08:52 PM   #7
cleszkie
cleszkie's Avatar
I agree with the last two posts. Thats how I adjusted mine. The adjustment procedure is described nicely in the original assembly manual. Takes only a few minutes to do.
VTBlazer -
You say that one should be able to kick down a gear no matter what gear you are in? I have the TH350, and with the detent "adjusted" it will kick down from 3rd to 2nd, but I've never had it go from 2nd to 1st. Do I have more adjusting to do?
cleszkie is offline   Reply With Quote
Old 06-08-2005, 09:50 PM   #8
vtblazer
vtblazer's Avatar
Originally Posted by cleszkie
VTBlazer -
Never said that at all, recheck the post.
The intent is to get you in a better gear ratio more suited to acceleration.
Old 06-09-2005, 05:03 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Thanks guys, now I just need to get that woman of mine behind the wheel so I can adjust it
Old 06-09-2005, 06:51 PM   #10
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Does it bog down.....if so it could be a vacuum advance problem.
maybe...I would check that out as well.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 06-09-2005, 06:55 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
VACUUM ADVANCE IS NOT IN USE
