69 failed emission's test......
350 with 600 holley.......
not much to adjust...... any thoughts......thanks mark ......running rich.... |
GEARHEAD
Have you tried the new power adder listed here? Emmissions legal power
I've tested it and if you can get a flourescent marker, it helps emmissions also. HG ![]()
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
10% mix of denatured alcohol in the tank has saved me everytime.....available at any hardware or Home Depot store. Otherwise, basic tuneup and check ignition timing, and idle speed.
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
Just Don't Stop!
![]() Join Date: Feb 2004
wow, in Texas, vehicles older than 21 years old don't have to be emissions tested only safty inspection...
1968 C10 build in process TT LSA/6L90e/9" |
Got Light Emitting Diode?
75 and newer here have to test, and no inspection. you could weld some cats in there
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
no inspections of any kind for any year in florida
I don't believe my eyes!! Some other state is actually more screwed-up than
California??? In the illustrious "Golden State" anything '73 or older is SMOG EXEMPT!! rwgregory
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
#8 | |
If you want to run regular Colorado plates, you have to have it tested EVERY YEAR regardless of the age of the vehicle. ![]() ![]() ![]()
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#9 | |
#10 | |
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
Not Mine But A beauty
its 76 n up here
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
Chevy Nuttttt
lean out the jets, retard the timing, and lean out the idle mixture screws. That wit hthe alcohol and you wil pass. or just move to a state that has no emitions on older stuff.
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell ![]() ![]() |
Everything the other guys said, and you might find this odd, but change the engine oil immediately before you go back to be retested. If it was close to passing, that alone could get you by.
my gas saver
when i lived in nashville metro they made us do emissions. my Z28 wouldn't pass one time, so i went and bought one of those "prolong" engine treatment kits. i went through after dumping that stuff in and it passed. now i'm out of the metro area and we don't inspect any year vehicles for anything, hell they'll let you ride around with no fenders and doors out here.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
#15 |
Lovin' Life in Miss.!
No suggestions not listed. I am courious though, what emissions equipment was on a 69? Heat stove and a pvc valve right? No EGR or any other junk?
The truck... you hear that? No really, you did hear that?!!! |
#16 | |
-Change the oil and filter (get that old polluted oil out of your engine. -New air cleaner -New fuel filter -Run a can of Pass Smog by CRC found in most parts stores, Walmart, etc. (this stuff works) I learned this from a technician that repairs vehicles that have failed emissions testing -Check for and repair any vacuum leaks -Check the timing with and without vacuum advance (less is good) -New spark plugs, wires, cap, rotor. Check your old spark plugs for color. They should be a light choclate color -Make sure the engine is thoroughly warmed up. -Make sure the technician does not raise and lower the RPM's quickly. This dumps excessive fuel into the system -And anything else the other members suggested
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
#17 | |
#18 |
In Washington, emissions testing isn't required fro anything 1980 or older or something like that. I have a 67 & 72 truck and a 91 Jeep, so anything in between that im not sure on, correct me if im wrong.
matt
Truck #1: 1972 Chevrolet K20 Cheyenne Custom Camper SB400, TH400, NP205 Truck #2 1967 Chevrolet C10 Custom Sport Truck 327 small journal, TH400 |
#19 |
2A674 Tank Rat
My '70 doesn't require emissions testing here in St. Louis County. Just a Safety inspection. I'd hate to have to get it tested!
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
#20 |
A couple of things,
I have seen multiple holleys with cracked metering bodies leaking fuel and running excessively rich, Power Valve blown or incorect will also cause rich running, they also now have power valve blowout kits available and would higly recomend one of these to anyone running the older holleys, the older holleys all it would take to blowout the power valve was for the engine to backfire back through the carb. In recent on my truck I had swapped out the cam to something a little bit more radical, prior to the cam swap I didnt notice any real richness but after the new cam it was pretty bad, I decided to try the pure Acetone treatment that someone else had posted a while back because of some minor pinging with 93 octane and octane booster was $10 bucks a bottle. Use 2-3 ounces to 10 gallons of gas, it quit the pinging and I didnt have anywhere near the fuel richness from the exhaust, I also noticed a slight improvement in gas milage. You can buy quarts of pure Acetone at Home Depot for $6 http://pesn.com/2005/03/17/6900069_Acetone/
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 06-10-2005 at 08:10 AM. |
#21 |
i think i am going to put a two barrel carb on this thing......
if that don't work i will......have buy a toyota....NOT |
#22 |
Registered Cruiser
Mark; Mine wont pass at idle unless I set it at 1100-1200 rpm. If you're rich at idle you could give this a try. Here in Nevada the idle speed can go as high as 1250 during a test. G/L
I intend to live forever. So far, so good. |
#23 |
I can`t believe some states make older vehicles go through emmisions.They are such a small percentage of the total vehicles on the road.And,even fewer daily drivers.My`99 ZR2 has both cats fryed.I punched-out the little egg-shaped one in the y-pipe($700 part)and Meineke replaced the rear one.It melted down and clogged the exhaust in two weeks.That got punched out.If it doesn`t pass next time(probably will),I`ll test it with an almost empty tank and racing(maqic juice)fuel.She`ll be burning real clean!
#24 |
well i kicked there butts......
i install a two barrel carb..rochester...... cut the co from 90 the limit to 46 the richness from 1475 to 86...... and you know what if runs great,,,,,,, passed like a champ......just a fyi..... removed the holley 600....... think i am going to stick with the two barrel.......going to check mileage.... i bet it go's up....... ![]() ![]() ![]() ![]() ![]() ![]() |
#25 | |
Got trucks?
Emerald OOGLY 68 ![]() |
