06-09-2005, 04:50 PM | #1 |
II Timothy 4:2
Where is the water coming from?
On my truck, whenever it rains or gets washed, I get water (not standing water, just wetness) on the floor where the kickpanels meet the floor in front of the doors. As a result, I have holes rusted through the kickpanels. I am guessing that somewhere there are some drain holes that are clogged from years of neglect. Any ideas where to start to look to either:
A) seal up the source of the water, or B) open up wherever the water is supposed to drain? Thanks!
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus" MY TRUE PRIDE AND JOY "Dangit, Bobby, people will see that oil stain and think I'm a drunk." |
06-09-2005, 04:53 PM | #2 |
December 21, 2012
Probably have a small leak around the windshield that lets water in. Check around the windshield for any wetness during and after washing your truck.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
06-09-2005, 04:57 PM | #3 | |
II Timothy 4:2
06-09-2005, 04:56 PM | #4 |
YES_____NO
Your vents on the kick panels are not open are they?
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
06-09-2005, 04:58 PM | #5 | |
II Timothy 4:2
06-09-2005, 04:58 PM | #6 |
More Cowbell....
On mine, the sealer that sits in the drip rail had dried up and chipped out allowing water to make its way between the layers, down the pillar, and through the kick panel vent.
Got rust holes on the kick panel.....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 06-09-2005 at 04:59 PM. |
06-09-2005, 05:03 PM | #7 | |
II Timothy 4:2
Well, my drip rails have certainly seen better days. Can I just run a thin bead of silicone or something in them to reseal them, or is there something that would work better?
06-09-2005, 07:57 PM | #8 | |
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! |
06-09-2005, 05:00 PM | #9 |
December 21, 2012
Well if water gets into the lower windshield it can leak onto the dash and down the drainholes in the dash to the floor around the kickpanels of the truck. Maybe you have a hole in the cowl area and its leaking through there onto the floor?
06-09-2005, 05:57 PM | #10 |
Its Magically Delicious
take a look at the antenna seal ...where the wire comes into the cab
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
06-09-2005, 06:05 PM | #11 |
simple fix - pull the cowl chip out the sealer where the firewall meets the cab (on top corners on both sides) and fill them w/ some type of sealer. we fix lots of them after every rain storm and that is the problem about 99% of the time. Even if it looks like it is fine dig the old stuff out and fill it up w/ sealer because it never looks bad but usually is.
Shawn |
06-11-2005, 03:21 PM | #12 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 06-11-2005 at 03:22 PM. |
06-09-2005, 06:09 PM | #13 |
you got a good pic of the exact location shawn ..... ??
06-09-2005, 06:31 PM | #14 |
nope, I don't have any trucks w/ out cowls on them, but if you take yours off you will see what I am talking about it's pretty easy to find
06-09-2005, 07:58 PM | #15 |
Old School, New Style
I have a window seal leak and it comes in on the dash at the corners. So as you can see by the previous post tends to come in from any number of locations. Good luck on your search.
Later, Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
06-09-2005, 10:48 PM | #16 | |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
06-11-2005, 02:30 PM | #17 |
My 70 leaks somewhere around the bottom of the windshield too. Now I know
what to look for. Thanks for the info guys! |
06-11-2005, 05:46 PM | #18 |
Better late than never
Mine is also leaking there. I had forgot about those two filled joints. Doesn't the windshield need to be pulled to clean them out and refill the seams?
1970 C/10 SWB Stepside |
