06-12-2005, 10:01 AM | #1 |
Dumb Q- New Tach w/ HEI kills engine....
Seems simple enough to wire a tach, two leads and a ground.......
I bought an entire new tach dash, this is a Counterpart Automotive job. Came with a Tach Harness and all........so one lead to bat switched and then the other lead goes that is for the coil, goes to the hei cap tach connection...........no seperate coil w/ hei. as soon as i connect the tach harness, truck dies??? Yes the cluster has a very good ground...... Any thoughts? Thanks! |
06-12-2005, 10:09 AM | #2 |
sounds like a bad tack that's shorted out internally
06-12-2005, 10:18 AM | #3 |
Make sure the posts going threw the tach mounting plate are not touch the metal housing( the 2 post on the back with red bushing on them.)
72 C-10 |
06-12-2005, 01:12 PM | #4 |
I had the same problem when i installed my new tach . Come to find out that the posts on the tach were upside down . So when i pluged in the wiring harness the red wire would wound up on the coil side of the tach . Your red wire should go to the positive side on the tach . I switched the wires on the plug in rather than taking the cluster of .
06-12-2005, 06:33 PM | #5 |
sees like thats what it is....
thx i'll check for a short...... |
06-12-2005, 10:16 PM | #6 |
Thanks Guys! That did it, the terminals on the back of the tach were reversed so that the harness went on reversed. I repositioned the terminals and the harness went on correctly......
Thanks! |
